Old 03-14-2011, 07:19 PM   #1
Going from 220v to 110v
I was given a jointer that it wired 220 but i only have 110. The motor is a baldor L3509 and it says it has 115v-208/230 so i think that means i should be able to rewire and plug it into 110v. Do i need to change only the plug or do i have to change something on motor itself?
maps79 is offline   Reply With Quote
Old 03-14-2011, 07:24 PM   #2
joed's Avatar
The motor needs to be rewired.
The info can be found here.
http://www.baldor.com/products/caddr...ing=40CMB-CONT
Do not PM with questions that can be asked in a forum. I will not respond.
Old 03-14-2011, 07:59 PM   #3
Licensed electrician
Just a reminder, if it drew 9 amps at 240 it will draw 18 at 120. Does the circuit have capacity?
Old 03-14-2011, 09:32 PM   #4
I=E/R
a7ecorsair's Avatar
Follow the Low connection, depending on rotation, and you should be in good shape.
Full load amps at 115 V is 11.8.
a7ecorsair is offline   Reply With Quote
220v vs 110v Baseboard Heater?? Master Brian Electrical 8 11-20-2010 12:13 AM
220v to 110v extension cord? glamabilly Electrical 14 09-26-2010 12:25 AM
Main box feeding 220v and 110v brearker box off a 50am breaker? uvamosk Electrical 30 10-14-2009 11:46 PM
Adding 110V outlets to 220V line MarcG Electrical 25 04-29-2009 07:04 AM
Convert 220V to 110V wrldruler Electrical 13 09-15-2008 12:55 PM
