Gfis W Open Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2010, 12:01 AM   #1
gfis w open ground
per nec, does a gfi have to be grounded? I have one that has an open ground. Is the easiest fix tieing it onto a copper water pipe w a clamp? If not can someone tell me what is?
thanks
brokenhammer is offline   Reply With Quote
Old 03-24-2010, 06:32 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 420
Yes, a gfci can work without a ground.
No, you cannot just take a wire to the copper pipe.
Are the rest of the receptacles in the house ungrounded?
jbfan is online now   Reply With Quote
Old 03-24-2010, 08:15 AM   #3
Rewards Points: 1,500
An ungrounded receptacle may be grounded by running a separate ground wire but that must go all the way to the panel where the hot wire was fed, or to the ground rod or to the (typically #6) wire that connects the former two.
There was an argument on another thread on this forum on how to ground a second ungrounded receptacle but what I gathered is that a separate ground wire from the second can be tied to the separate ground wire of the first when both are on the same branch circuit.
Old 03-24-2010, 08:37 AM   #4
Master Electrician
Rewards Points: 3,824
If you can get enough access to run a separate ground wire as described, there is no reason not to run a new branch circuit cable to the oulet instead.
brric is offline   Reply With Quote
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Want to use a pulley /counter weight to open metal hatch door to cellar MACrowley Building & Construction 4 02-22-2010 05:41 PM
Bonding Ground in Conduit jamiedolan Electrical 5 01-26-2010 10:14 PM
Temporary Genrator Ground theatretch85 Electrical 32 08-05-2008 12:05 PM
Grounding VS Bonding BillyD Electrical 24 06-22-2008 12:14 PM
