Gfic For Kichen Needed? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 10:37 AM   #1
gfic for kichen needed?
do i need gfic for outlets on both sides of kitchen sink thx
doctordog is offline   Reply With Quote
Old 05-16-2011, 10:42 AM   #2
joed's Avatar
Rewards Points: 12,362
If this is new work then yes. If this is existing then it could be grandfathered and not required until the electric is updated.
Old 05-16-2011, 10:47 AM   #3
Too Short? Cut it Again!
Not sure what a gfic is but your kitchen, since it is a wet area at times should have a ground fault circuit interrupter (GFCI) outlet at the start of the circuit installed. Good ones run under $15 these days even if you pay retail. The GFCI will protect all other things ahead of it on the circuit.
Hopefully your frig and microwave are on a different circuit.
Old 05-16-2011, 10:54 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Not necessarily GFCI receptacles, but GFCI protected receptacles. In a dwelling, all receptacles that serve the kitchen countertops have to be GFCI protected, whether next to a sink or not. You can do this by a GFCI breaker for that circuit, or by a GFCI receptacle that protects itself and other receptacles down line (daisy chaining).
As Joe mentioned, new work yes, existing grandfathered. Either way, it’s the best idea to have them.
Kyle
Old 05-16-2011, 10:57 AM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Originally Posted by sdsester View Post
...The GFCI will protect all other things ahead of it on the circuit...
Oops...you got that backwards. Doesn't protect anything ahead of it, protects things after it.
Kyle
Old 05-16-2011, 11:24 AM   #6
oops. typed too fast. You are right of course.
Old 05-16-2011, 08:39 PM   #7
Missouri Bound's Avatar
Any outlet withing 6 feet of the edge of the sink requires GFCI protection.
The Following User Says Thank You to Missouri Bound For This Useful Post:
doctordog (05-18-2011)
Building a 20' x 20' wood frame garage bgbrown125 Building & Construction 38 08-07-2011 01:53 PM
Combustable air, how much is needed? Lee Roy HVAC 9 10-27-2010 10:17 PM
hardwired doorbells and GFIC BlueBSH Electrical 5 07-30-2010 01:32 PM
Wire Needed for GF / Arc Fault breaker jamiedolan Electrical 13 09-20-2009 08:15 AM
Placement of GFIC allen1466 Electrical 3 03-24-2006 08:46 PM
