Old 11-23-2012, 09:54 AM   #16
TTW
TTW's Avatar
GFIC duplex tripping without anything plugged in
Ah yes, the good old days, i am retired CG. 9 years at sea.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 11-27-2012, 09:06 AM   #17
custom user
Two and a half at sea in my four years. I probably should have stayed in, wish I had that check coming in each month now.
Update on the ground fault gremlin: Yesterday I went back to revisit the issue. I put the original GFCI receptacle back in with just the line connected. No problem. Hooked up the load lines, no problem. The outside receptacle is on a different circuit, neutral might be tied in, but it looks inside. No water leaks anywhere.
The only change is that I've removed and reinstalled two of the receptacles on the circuit. So maybe it was a ground wire touching a hot or neutral wire and the insulation breaking down a bit. So it's "solved" for now.
JasperST is offline   Reply With Quote
Old 11-27-2012, 09:50 AM   #18
TTW
TTW's Avatar
Glad to hear you are ok now, yes there was probably something screwed up in one of the other boxes.
Actually did my last 10 in the reserves, so am waiting 'till I'm 60. Not too long now...
Tapping off of an existing duplex outlet OntarioDYI Electrical 2 09-02-2012 11:54 AM
GFCI in a 2 duplex gangbox and load out: DiegoJames Electrical 5 03-01-2012 10:49 PM
Adding a duplex outlet drjay9051 Electrical 5 03-05-2011 10:15 AM
Refrigerator Tripping GFI, is it safe? impius Appliances 37 12-20-2010 09:21 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
