GFI Wiring - Ground Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2011, 12:40 PM   #1
Does the GFI outlet require a separate ground wire back to the panel, or is grounding to rigid conduit sufficient?
lcmcauley1 is offline   Reply With Quote
Old 07-07-2011, 12:43 PM   #2
Licensed electrician
Rewards Points: 1,266
If the conduit system is continuous a jumper can be run between the box and the device.
wiring subpanel wire too short kenmore Electrical 8 06-02-2011 04:34 PM
4 wire occupancy switch wiring.. FLASHING lights?? darin00 Electrical 3 12-18-2010 08:38 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 04:26 PM
