Gfi Wire Size - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2011, 07:47 PM   #1
gfi wire size
If a bathroom has a 20 amp breaker can you use 14 wire and have a 15 amp gfi that says 15 amp 125 v 20 amp feed thru.
julie112 is offline   Reply With Quote
Old 05-24-2011, 07:48 PM   #2
Master Electrician
Rewards Points: 3,768
No you can not.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
julie112 (05-24-2011)
Old 05-24-2011, 08:23 PM   #3
Rewards Points: 324
just change the 20 amp breaker to 15 amp and you will be fine.
oleguy74 is offline   Reply With Quote
Old 05-24-2011, 09:10 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
I don't get it. How does the bathroom have a breaker? Do you mean the circuit is already run? Why are you asking "can you use..."? Are you planning new work, or asking about existing?
These are valid questions since bathrooms used to be able to have 15A circuits for receptacles, but no longer.
Either way, NO, you CANNOT have #14 on a 20A breaker.
Speedy Petey is online now   Reply With Quote
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 10:38 AM
wire size for 160' feeder to subpanel steveski Electrical 3 05-21-2011 10:41 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
