GFI Will Not Reset Will Line Is Hot - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-07-2008, 01:11 PM   #16
thanks for the input Williswires... I did like you suggested. I disconnected the load and the GFI set with only the line. From there, I checked each box until I found the switch to the lights, the black wire had a worn spot that somehow bared the wire and was shorting. A bit of Electrical tape and all is working well. Thanks to all... I learned something valuable. There was also a short How To on the intranet on GFI and it had a great suggestion as well. Once you connect your hot wires to the GFI, place a piece of electrical tape over the connections to prevent any accidental/incidental contact.
soccerdude is offline   Reply With Quote
Supply Line Touching Roof MikeinBurien Electrical 14 07-13-2008 11:26 AM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
Hot Water Recirculating Line jdupre Plumbing 9 01-06-2008 07:49 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 07:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 08:19 PM
