GFI Troubleshooting - Electrical - DIY Chatroom Home Improvement Forum
Old 02-19-2009, 02:06 PM   #1
GFI troubleshooting
I recently changed the light fixture in my bathroom. I wired each color to the same color wire (black, white, bare). Now the light works, but I have 2 GFI outlets that don't work. When I press the test button it lights up, but the reset button doesn't stay down (no tripping "click" either). Does this have something to do with the light fixture?
Hopefully someone out there can help me, I'm clueless!
arm1tage is offline   Reply With Quote
Old 02-19-2009, 02:32 PM   #2
Rewards Points: 1,442
Were the GFI outlets pre-existing and undisturbed?
Did you push the reset button in far enough?
I would think that there is some error in the circuit wiring seeing that the GFI isn't resetting whether the light is continuously on or is off. While a defect in a light fixture sometimes shorting the neutral and ground together is occasionally seen, I think there is something more here.
Unplug everything from the circuit and try again. Maybe you have a defective hair dryer or night light or something like that causing the ground fault.
Old 02-19-2009, 07:44 PM   #3
The light and the GFCI are probably not related, not on the same circuit.
If your house is over 10 years old, check around to see if anything else is off. The other bathrooms, outside, garage are typical places to look.
Unplug everything from the non functioning receps.
If your house is newer, the only thing on the GFCI will be the bathroon receps.
If nothing else is affected, turn off power and remove the GFCI and find out how many wire are in the box.
220/221 is offline   Reply With Quote
Old 02-19-2009, 07:49 PM   #4
Rewards Points: 2,350
Sometimes you have to push the reset in quite far to set it, maybe using an ink pen or pencil from the eraser end to push it in.
Old 02-20-2009, 03:46 AM   #5
Well the solution was to just reset the breaker. Glad it was that easy!! Thanks for all the help.
Thermostat Wiring & Troubleshooting guide Hippie HVAC 7 10-25-2009 11:02 AM
Tips On A/C Blower Troubleshooting? DeeTee HVAC 7 05-21-2009 01:24 PM
Troubleshooting Garage Light capt2 Electrical 10 11-18-2007 11:41 AM
Help with voltage troubleshooting epicurux Electrical 5 07-02-2007 08:51 AM
