GFI Trouble - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2011, 07:52 AM   #1
GFI trouble
After powering off my home to do some repair work, my 50 amp GFI in the panel to my hot tub trips immediately upon reset. Additionally, my 30 amp GFI in the panel to my pool will run the pool for about 10 minutes and then pop off. I powered off the house because I was doing some repair work. I did have an to disconnect an outside outlet temporarily and just used wire nuts to tie the hots, neutrals, and ground together. Could the disruption to the outside outlet (I believe has a GFI breaker in panel) be the cause of the problem? If not, ?????
hagenw is offline   Reply With Quote
Old 08-09-2011, 08:30 AM   #2
the Musigician
DangerMouse's Avatar
There might have been an unmarked white switch leg that you accidentally tied to the white bundle?
...and I HOPE you mean you tied them together individually.....
DM
Old 08-09-2011, 09:59 AM   #3
I did bundle things individually. However, the problem with the hot tub happened before I pulled the outside outlet. Could re-powering have caused a surge to the GFI's and caused this problem?
Old 08-09-2011, 10:31 AM   #4
the Musigician
Anything's possible. Did you make sure line in and load out were in the same places as the one you pulled?
DM
Old 08-09-2011, 11:55 AM   #5
I did so, yes.
Carrier Infinity 96 Trouble Code 25 travissmith25 HVAC 2 11-18-2014 09:37 AM
Will I have trouble growing grass here? Red Squirrel Landscaping & Lawn Care 5 04-14-2011 02:04 PM
Trouble removing T&P Valve from water heater secutanudu Plumbing 3 04-07-2010 06:35 PM
Trouble removing shower wall tiles astroboy Kitchen & Bath Remodeling 2 01-30-2009 10:50 PM
wiring trouble? brad25 Electrical 5 11-27-2005 07:07 PM
