GFI Tripping When Light Turned Off - Electrical - DIY Chatroom Home Improvement Forum
Old 08-13-2012, 11:57 AM   #1
GFI Tripping when light turned off
I have read some posts on this issue, however I wanted to get input on my specific situation.
I have a circuit in my house which has a UPS plugged into a GFI. The UPS is used to keep my computer running long enough for a controlled shutdown in the event of a power failure. There are numerous times when the GFI trips when the room light is turned off. I am a computer guy not an electrician but I am generally handy. Any insight would be appreciated.
rogervin is offline   Reply With Quote
Old 08-13-2012, 03:47 PM   #2
kevinp22's Avatar
Rewards Points: 252
First, it is generally a bad idea to have a UPS plugged into a GFCI unless you have no choice. Since surges are sent to ground, any surges that result in 5ma or more will trip the gfci.
Is this light and switch
1. on the same circuit as the GFCI
2. If so, is it downstream of the GFCi
If downstream it could be that the switch is bad is throws a ground fault while being turned off.
kevinp22 is offline   Reply With Quote
The Following User Says Thank You to kevinp22 For This Useful Post:
PaliBob (08-15-2012)
Old 08-15-2012, 03:20 AM   #3
Try unplugging the UPS and flipping the switch. That would show whether the switch alone is at fault.
freedomlives is offline   Reply With Quote
The Following User Says Thank You to freedomlives For This Useful Post:
Old 08-15-2012, 06:00 AM   #4
Is the light fed from the GFI?
What kind of lamp is in the light? Maybe try a different kind of lamp.
Does the GFI trip when the UPS is not plugged into it?
Why is UPS plugged into a GFI?
parman is offline   Reply With Quote
Newly installed GFCI outlet trips when ceiling fan/overhead light is turned on vash1012 Electrical 8 07-15-2012 06:47 PM
GFCI trips when light switch is turned off technicholas Electrical 6 01-02-2012 10:26 AM
3 and 4 way switches - power to first light mmrossen Electrical 3 12-04-2011 09:07 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Light Switch Keeps Tripping Breaker jackiesmom Electrical 23 05-24-2007 02:27 PM
