GFI Tester - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-11-2010, 09:22 PM   #31
Originally Posted by Yoyizit View Post
I had a schematic for one off the Internet.
So they will read 7 of the ~30 ways to wire or not wire a 3 terminal outlet and they depend on only one fault to be present at a time. You trade convenience for being lied to once in a while. Now I'm glad I never bought one.
Yes... so true. It lied from day one to me...lol. And I wasted so much time because I believed it.... GRRRR..... Live and learn....
WRBJR is offline   Reply With Quote
Old 06-12-2010, 04:22 PM   #32
Mad Scientist
I pretty much only use my plug in tester for 3 things:
A handy light to plug in to an outlet while I'm flipping breakers, so whoever is helping me can tell me when it's off.
A way to quickly test if an outlet is in fact protected by an upstream GFCI. (unless it's an ungrounded circuit, then it's no good for that..)
A quick check to see if an outlet is grounded. (Though frequently in older houses, when the tester shows normal, I'll still pull the outlet and check for a bootleg ground.)
Basically, if the tester shows any indication other than "Normal" I'll ignore what the chart says, grab my DMM and check it out myself.
McSteve is offline   Reply With Quote
Tester g60vwr Electrical 3 03-05-2010 03:59 PM
Circuit tester shows open neutral; multi-meter says something different. fredgmeyer Electrical 11 10-26-2009 12:41 PM
Odd behavior of voltage tester across switch terminals? darsunt Electrical 12 08-20-2009 08:28 PM
Ground tester? Ultrarunner2017 Electrical 24 01-13-2009 01:38 PM
Clamp on Amp Tester Help stagger19 Electrical 3 03-07-2007 08:26 PM
