GFI For Shower Lighting? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-24-2011, 05:19 PM   #1
GFI for shower lighting?
Hi guys,
I'm helping my mother in law do some renos at her new house and right now we're tackling the bathroom. Her interior designer made an electrical plan for me. On the plan it shows 6 pot lights, one of which will be GFI protected ( the one inside the shower stall)
I've had people tell me that the GFI will be constantly tripping from humidity if i do that. so......to GFI protect or not to GFI protect?
MitNotrof is offline   Reply With Quote
Old 11-24-2011, 05:27 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
You can if you want, but you don't have to.
Old 11-24-2011, 05:27 PM   #3
Master Electrician
Rewards Points: 3,870
Not a code requirement for GFCI. A recessed can in a shower requires a shower trim which shoulde seal the fixture from humidity.
brric is offline   Reply With Quote
Old 11-24-2011, 05:52 PM   #4
Awesome, thanks guys.
Old 11-24-2011, 06:02 PM   #5
Sparky
Rewards Points: 510
the manufacturer may require GFCI connection. but the NEC does not
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
mpoulton (11-25-2011)
Old 11-25-2011, 12:27 AM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,938
Some (perhaps even "many" or "most") shower fixtures say to use a GFCI in the instructions. If it says to, then you must by code. I would not be very comfortable without it. Humidity will NOT cause nuisance tripping. If it trips from humidity, it's protecting you from a dangerous problem.
EDIT: I poked around online, and it looks like most do not require GFCI protection. I had installed two types that did, and seen one other that did, but it seems those are in the minority.
mpoulton is online now   Reply With Quote
Old 11-25-2011, 07:57 AM   #7
For real?
Change "Some (perhaps even "many" or "most")" to "almost no".....
I have NEVER seen a typical shower trim that required GFI protection.
Now a bath fan, that is a different story....
The Following 4 Users Say Thank You to Speedy Petey For This Useful Post:
brric (11-25-2011), jbfan (11-25-2011), mpoulton (11-25-2011), SD515 (11-25-2011)
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
General design and lighting? mrs1885 Landscaping & Lawn Care 14 01-06-2011 03:12 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
