Gfi Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 11-27-2011, 06:00 PM   #1
gfi problems
put in a pole lamp and gfi receptacle with on and off switch. after heavy rain and wind it went out and would not reset. this has happened 3 times with 3 switches. everytime I hooked up a new switch it works for days, weeks, months (or until the next heavy rain and wind. the gfi yellow light in on and when I test the receptacle it is showing electric current but noting will work when plugged into it. any thoughts
nothandygunny is offline   Reply With Quote
Old 11-27-2011, 06:17 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,600
Moisture is building up somewhere, and providing a leakage path to earth
which trips the gfci.
Some locations are just too wet for electricity,
And outdoor fittings suffer from moisture build up.
Totally sealed enclosers suffer badly from this sometimes.
If you cant find how or where the water gets in,
then you might not be able to have one there!
dmxtothemax is online now   Reply With Quote
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 08:44 PM
Multiple problems in 3 year old house I just purchased swenard Plumbing 12 08-31-2009 03:53 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 02:04 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
