Old 03-27-2008, 12:09 PM   #1
GFI Plug Troubleshooting
Hello,
Looking for some insight into a GFI issue. I have a cicuit with a few lights and receptacles with a GFI being the second to last device on the circuit.
The green power light comes on, however the GFI will not reset, and therefore there is power in the box but no power within the plug.
I bypassed the GFI to the downstream plug and the downstream plug worked fine, therefore Hot / Neutral are correct, all lights and outlets function properly and the main breaker does not trip.
I hooked up the Ground / Hot / Neutral to the "Line" side of GFI and left the downstream plug out of the picture. Still no Power or Reset, but a green light ...
Anybody have ideas of potential problems that could be occuring, I am on my second GFI plug, doubting that both are faulty,.... I have read that the GFI is not relying on the ground wire to function properly, can I eliminate that from my search ?
bryanchr is offline   Reply With Quote
Old 03-27-2008, 12:42 PM   #2
Licensed Pro
Make sure you are pressing the reset button far enough in to reset the device. Some units require more pressure than others.
Make sure the hot/neutral are not reversed prior to the GFCI. Just because lights and receptacle work, does not mean the wiring is correct.
Double check for proper wiring (hot to brass screw side, neutral to silver screw side, both on the line side of the device).
Make sure there is no contact between the neutral and the ground wires.
Old 08-22-2008, 02:21 PM   #3
terryfitz's Avatar
I doubt both are bad. Commonly, this problem is caused by not hooking the conductors up properly. The power coming IN to the device goes into the connections marked LINE and the power going out to the next device is from those marked LOAD. Think of throwing a fishing line into the water and pulling a load of fish out. Line in; load out.
terryfitz is offline   Reply With Quote
Old 08-22-2008, 02:29 PM   #4
the light on the GFCI can be confusing, some brands the light turns on when it has power, and some brands the light comes on when it has tripped.
daxinarian is offline   Reply With Quote
Old 08-22-2008, 06:28 PM   #5
SD515's Avatar
Verify that there isn't another GFCI already on the circuit. They usually don't play nicely together. Plug an extention cord into another known correctly wired circuit. You can test the ext cord with a voltmeter...narrow slot [hot] to wide slot [neutral] should be 120V, narrow to ground-120V, wide to ground-0V. Then check your wire feeding the GFCI...black to ground of ext cord-120V, white to ground-0V, ground wire (of GFI feed) to wide slot-0V. If this checks out and no other GFI before it, it should work.
More On This Topic
Hi! My name is Stephanie and I’m here on behalf of expertvillage.com. Please visit our web site at www.clickincomputer.com. These are front power switch, reset switch, hard drive light and power light. These are where they’re going to connect... Read More »
Wiring Dryer Outlets
Wiring Dryer Outlets by Expert Village
Now were going to reinstall the box its for four O box which means thats it for four inch four inch box for the dryer plug. Which is a two twenty power supply and this is what the plug looks like. I am going to be installing it on this side about right... Read More »
On behalf of Expert Village.com my name is Luke and I'm with Friendly Computers and I'm here to show you on how to install power supply. Now what your going to want to do basically every case has it's set up cables. It has power switch, power LAD, hard... Read More »
This is Zach with Expert Village and today we are going to talk about trouble shooting your hard drive if you got an external storage device connected and it's not showing up on your desk top. First thing you want is to always make sure that everything... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you Part 6 of replacing an old electrical outlet. Next we are going to install a new plate to match our outlet. After that go ahead and turn the power back on. To test... Read More »
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 09:07 PM
Plug Sockets - Basic Question chris_stfc Electrical 6 12-25-2007 05:03 PM
Issues with appliance plug hgiljr Electrical 1 03-17-2007 08:09 AM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 10:03 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
