Old 04-13-2009, 04:54 PM   #1
gfi outside is it safe
Hello... I recently had someone install a outdoor gfi on the balcony. I noticed the entire box was exposed. The gfi was not built in to the stucco of the house like the ones that came with the house were. Is it safe? The contractor gave me some reason I dont understand why he did not install the switch in the stucco.
diymark is offline   Reply With Quote
Old 04-13-2009, 05:10 PM   #2
Electrical Contractor
If it is a weather proof box with an inuse cover it is safe.
If you have questions about the box, snap a picture for us to see.
The reason I don't try to install a box into stucco, is I won't take the time to repair the stucco afterword, which may take longer for me than the install of the receptacle.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 04-13-2009, 05:12 PM   #3
Remodeling Contractor
If it is a waterproof box it is fine. Installed as a surface mount to avoid chipping the stucco as well use using a none waterproof box for a recessed application may still allow water to get in to the box through the stucco, so you would have a worse job. If installed prior to the stucco as your old house, a special box made for that application would have been used.
Old 04-13-2009, 05:20 PM   #4
Xtreme DIY'r
Post a pic if you can
It shoud have an in-use cover, grey or clear
It should not have one of the old-style covers
Old 04-13-2009, 05:23 PM   #5
thanks.... I just wanted to be sure it is safe. Also.. it doesnt look as nice as the gfi that was built into the stucco by the builder. It is a waterproof box but I was concerned because it is always exposed since it is mounted on the outside of the stucco. I thought surely water could find its way in there.
Old 04-13-2009, 05:28 PM   #6
Cut the stucco with a Fein Multi-Master and you will not chip the stucco.
Old 04-13-2009, 05:32 PM   #7
Spend $300 for a tool that I may need 3 times a year?
No thanks
I would like one though!
Old 04-13-2009, 06:17 PM   #8
Licensed Pro
No thanks
Dremel has a less expensive one ($99) not as good or as rugged, but for those 3-4 times a year you need it, it is well worth the $.
Old 04-13-2009, 06:58 PM   #9
No thanks
It will be handy for trimming plates, cutting any material without chips for cut-in boxes. I am an electrical contractor and had one for 15 years now. Actually I now have three multi-masters. Just wait until you can afford or can justify the Fein, the others are not accurate enough for professional work.
Old 04-13-2009, 08:21 PM   #10
I bought a MM a while back. I don't know how I managed all these years without one. I'll bet I have used it a dozen times this month alone. It's like a sawzall, but it has finesse.
georgiasparky is offline   Reply With Quote
Old 04-13-2009, 09:17 PM   #11
So the reason the contractor may have installed the surface mount is because it is safer than trying to install it recessed in the stucco? Is there a way to install the gfi in the stucco waterproof/tight/ safely? Or would that not be recommended? It looks so much better recessed.
Old 04-13-2009, 09:25 PM   #12
You can install it anyway you want. All it takes is time (your contractor's) and money (yours) to flush mount it. And, it may involve other crafts (i.e., drywall). If installed properly, it just doesn't matter -- both are safe.
A picture would be helpful.
Old 04-13-2009, 10:23 PM   #13
Well, I really could use a Fein mulimaster, but the patent ran out a year or two ago, and now there are a few copies.
I just bought the Rockwell Sonicrafter copycat for $139 and a bunch of blades were included. The dremel was to small for my uses...
Here is a short video of the Rockwell at work; the guy uses it as a hammer, which I wouldn't do, but this 2.3 amp tool is fantastic so far: http://www.youtube.com/watch?v=ew7ZJx0e1ag
It is not a Fein, but it is a really good copy, in my opinion. Now I don't have to borrow the Fein from different buddies anymore...
I couldn't justify the outrageous price for replacement blades on the Fein.
The Rockwell is burly.
Timster is offline   Reply With Quote
Are old 2 prong sockets safe for modern electrical appliances? saturninered Electrical 17 10-09-2008 12:25 PM
Is it safe to plug in this flourescent fixture? doofalot Electrical 2 08-16-2008 02:27 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Help Me.....installing Wall Safe shaw Carpentry 7 10-01-2006 05:50 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
