GFI Outlet Trips When It Rains - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-26-2009, 08:13 PM   #16
puzzled for reason of trip, GFCI [line] after rain
I'm gonna go out on a limb. This is a far out theory, but still possible. Maybe there is an open [mechanical] joint somewhere and moisture seeps in around one of the outlets downstream (of the GFI recept.) That could cause for leakage current to be present and trip the device!!! for not finding the problem!!!
spark plug is offline   Reply With Quote
Old 05-26-2009, 08:35 PM   #17
another possible source of (creeping) moisture
Since you mentioned in one of the "back-and-forths" that ALL the connections to the lights and outlets are underneath the house, there's one possibly strong source for the problem. Unless the wires are in moisture proof conduit and the joints are protected against wetness, there could be conductivity to GROUND. I can tell you from personal experience that there is significant moisture in that location even when it doesn't rain!!!now! later!!!
Old 05-27-2009, 11:47 AM   #18
After a rain you might be able to find the leakage to ground with an ordinary ohmmeter. Let's say a passing value is >1 megohm.
Old 05-27-2009, 12:08 PM   #19
joed's Avatar
Rewards Points: 13,278
Actually I think from past testing you need a value of 3-4 megohms.
Old 05-27-2009, 12:45 PM   #20
"all outlets were replaced"
including the GFCI outlet?
I'd also replace the cover with an in use wet cover - the bubble type
Old 05-27-2009, 01:19 PM   #21
OK, pass is >4 MΩ, fail is <30kΩ.
Old 10-31-2012, 05:05 PM   #22
Similar problem
I have a similar problem.
In our 8 month old house we have a GFI outlet in our garage that popped last night. I removed all items plugged into the outlets on that circuit and still it pops. I replaced the GFI (hoping it was bad) and the new GFI pops.
Would it make sense to jumper around the GFI and then test each outlet? Will this help me locate the general area where the problem exists?
I am also calling the builder but I am hopeful I could fix it myself.
Any suggestions?
cmlyki is offline   Reply With Quote
Old 10-31-2012, 10:00 PM   #23
I see this thread is old, but for future when trying to isolate problems similar, you can save time by disconnecting in the general center of the circuit, determine if problem is upstream or down, then go to the next center of where you determined the problem is etc etc. just a tip, instead of starting at one end, begin in the middle.
To the new poster, is there possibly another gfi on that circuit? If a gfi is on an already protected gfi circuit they can trip eachother. Or so i have been taught.
Dont mean to question your ability because i dont know you, but how sure are you that you put the wires on the correct terminals on the new plug? There is a line and a load side. Make sure the correct orientation with where feed and load goes on the new gfi.
Marc05 is offline   Reply With Quote
The Following User Says Thank You to Marc05 For This Useful Post:
PaliBob (11-01-2012)
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
