Old 09-13-2008, 03:03 PM   #1
GFI outlet tripping?
I have a new outlet (6 mo. old) that we had put in for our dryer. I believe it is a GFI outlet as it has the two little buttons in the middle. The outlet has been tripping when using the dryer. It doesn't happen every time, but enough to be annoying when the dryer cuts out in the middle of a cycle.
Is this an issue with the outlet, or dryer? The dryer is rather old and I'm worried there may be an issue with it, rather than the outlet itself. Any advice?
k.kuenn is offline   Reply With Quote
Old 09-13-2008, 03:04 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Try another GFI, and also make sure that it is rated for the load that is being plugged into it. If the GFCI is tripping still after replacing, then have the appliance checked out.
Multiple Circuits - Same Outlet box Revnjeff Electrical 2 09-04-2008 09:17 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 11:55 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
