Old 10-15-2010, 10:51 PM   #1
GFI outlet keeps tripping
Hi There,
I'm a home improvement novice at best so pardon the what might be simple question. I have an outlet that only has a microwave plugged in that keeps tripping. I assumed at first it was caused by the microwave since it was quite old. I replaced it and the new microwave causes the same issue. It will be fine for a few hours then out of nowhere just trips. The only other items plugged in (different outlets) in the kitchen are the stove and fridge. No issues w/them. Any help is appreciated.
cambria is offline   Reply With Quote
Old 10-15-2010, 11:33 PM   #2
Mad Scientist
It could be a bad GFCI, or bad wiring somewhere, or there might be something plugged in to an outlet downstream of the GFCI that has a problem.
For a start, trip the GFCI with the test button and see what other outlets in the house lose power, if any.
McSteve is offline   Reply With Quote
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Replaced Outlet, but now tripping the circuit breaker bman598 Electrical 9 05-21-2009 08:35 PM
GFI outlet tripping? k.kuenn Electrical 1 09-13-2008 03:04 PM
