GFI Outlet Keeps Tripping - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 08:36 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by skennedy25 View Post
nothing was plugged into the gfi outlet and the freezer was the only other thing plugged into one of the outlets
A megger would be your next best bet to solve why it is tripping.
Old 07-26-2012, 09:14 AM   #17
Licensed Pro
Check for ants in the outside receptacles... they love to nest there and will cause a GFCI to trip.
Old 07-26-2012, 10:12 AM   #18
Rewards Points: 4,796
Is there a tester I can buy from Lowes or home depot to check the 3 outside outlets and then the gfi outlet
Yes and they are relatively inexpensive. I strongly recommend getting one even if it weren't for this problem. Make sure you get the one that also tests GFCI.
jeffnc is offline   Reply With Quote
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
washer/dryer frying my outlet dontwannadiy Electrical 15 07-27-2009 11:52 PM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 10:27 PM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
