GFI Outlet Bathrooms - Electrical - DIY Chatroom Home Improvement Forum
Old 09-30-2014, 08:22 PM   #1
Rewards Points: 81
I have 2 bathrooms that are back to back. I want to add a dedicated GFI to each of them. I am in the middle of gutting the 1 bathroom, so the drywall is removed on 1 side of the wall giving me access to the wall cavity. My question is can I run a 12 guage 3-wire from the panel to a junction box in the attic. Then, dropping the wire down through the wall, use the black wire for 1 GFI; the red wire for the other GFI; then tie the neutrals and grounds together in the junction box? Back at the panel, the black and red would each get its own 20A circuit breaker.
cougar01 is offline   Reply With Quote
Old 09-30-2014, 08:50 PM   #2
Rewards Points: 248
Yes but you have a couple of considerations. One is that they will need to be on different phases so the nuetral does not get overloaded. Another would be if you need to make it compliant with the current electrical code then the breaker handles will need to be tied together.
Jake. is offline   Reply With Quote
Old 09-30-2014, 08:54 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
You can do it that way but I would not use a jb in the attic. Drop the 3 wire from the panel into one nox and run a 3 wire to the other box.
Also, if no other receptacles or lights or fans will be on the circuit, you can use 1 circuit for both baths.
Coastal South Carolina
Old 09-30-2014, 09:04 PM   #4
Master Electrician
Rewards Points: 3,966
Why would you run a three wire to the second box?
brric is online now   Reply With Quote
Old 09-30-2014, 10:55 PM   #5
joed's Avatar
Rewards Points: 13,752
You should also use a double pole breaker not two separate 20 amp breakers.
Old 10-01-2014, 05:57 AM   #6
A "Handy Husband"
rjniles's Avatar
Senior brain fart. 2 wire to the second box.
Old 10-02-2014, 06:25 PM   #7
Rewards Points: 81
Thanks for the responses. I considered only using 1 circuit for both outlets, but wanted to avoid having to walk down the hallway to the other bathroom to reset the GFCI.
Old 10-02-2014, 06:42 PM   #8
A "Handy Husband"
rjniles's Avatar
How many times have you tripped a bathroom (or kitchen) GFCI? I have lived in this house for 9 years and have never tripped one. 7 years in the previous house and 20 in the one before that- never once. The house before that did not have GFCI.
Outside GFCI's are another story.
Old 10-03-2014, 01:11 AM   #9
Rewards Points: 248
You dont have to tie both receptacles to one GFCI either. You can put the HR AND the power out to the other bath on the line side of the first GFCI receptacle and just put in another receptacle in the other bath.
The Following User Says Thank You to Jake. For This Useful Post:
rjniles (10-03-2014)
Old 10-03-2014, 05:49 AM   #10
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
Run one circuit, with the money you saved on wire you can just used two GFCI receptacles , splice through the first box and pig tail that GFCI so it does not trip the GFCI in the other bathroom.
"Government is not the solution to our problem; Government is the problem."
HARRY304E is offline   Reply With Quote
GFI outlet won't reset; voltage at lower terminals--bad outlet? jbeall Electrical 2 06-07-2013 08:52 PM
Dual Voltage Combination Outlet Perry401 Electrical 6 04-12-2013 05:34 AM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 08:06 AM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Outlet not working, reading "open ground" syren Electrical 3 04-19-2010 04:20 PM
