GFI Outlet In Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 07-03-2014, 03:45 PM   #1
Question
GFI outlet in bathroom
I have a home built in the 90's. The bathroom outlets themselves are not GFI but they are tied to a GFI circuit that has the GFI outlet in the garage. I guess that's how they did it back then.
I'm replacing the standard outlet in the bathroom and I don't know if I can/should install a GFI outlet in that bathroom with it already tied to a GFI circuit from the garage? Is it bad to have it doubled up like that?
Thanks for any advice.
joregon3597 is offline   Reply With Quote
Old 07-03-2014, 03:52 PM   #2
Licensed electrician
Rewards Points: 1,888
There is no point to a second GFI in the circuit if it is already downstream of the garage GFI.
Old 07-03-2014, 05:20 PM   #3
Rewards Points: 544
A properly installed gfi protects whatever is downstream of it regardless of how far. As noted, you would just be doubling up. Ron
ront02769 is offline   Reply With Quote
Old 07-03-2014, 05:29 PM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,790
Sounds normal to me, but you otta just trip/test that garage gfi and make sure that your bath recepticals are dead.
While normal, it does not have to be wired that way.
MTN REMODEL LLC is offline   Reply With Quote
Old 07-03-2014, 08:01 PM   #5
Rewards Points: 3,396
unless you want to pigtail to the gfci in the garage, and add another gfci to the bath, so if the garage trips it won't turn off the bathroom, or if the bathroom trips you don't have to go to the garage to reset.
imo
ritelec is offline   Reply With Quote
Old 07-03-2014, 08:18 PM   #6
imo
Which might make alot of sense for $10, when others do not realize where the controlling GFI is located, or somebody puts shelving and resultant garage crap over the garage GFI.
Old 07-03-2014, 10:10 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,608
So where is the gfi on this circuit located ?
In the panel ? only in the garage ?
Where do the bathroom outlets tie into this circuit ?
You description is a little muddled and we need to be
sure that the bathroom outlets are not already gfi protected !
If so ? why do you want another gfi (which may or may not work).
Please elaborate !
dmxtothemax is offline   Reply With Quote
Old 07-04-2014, 06:58 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
My home was originally like this. I think it's extremely stupid. Difference was I had a GFI breaker in the garage.
You would need to go to the original GFI and place both sets of wires on the LINE terminals. Then install GFIs at the other locations, also only using the LINE terminals.
I'd MUCH rather have the GFI local to where it is being used. Although, I can honestly say I have never even tripped a GFI in my home.
Old 07-04-2014, 08:39 AM   #9
Rewards Points: 826
Originally Posted by Speedy Petey
My home was originally like this. I think it's extremely stupid. Difference was I had a GFI breaker in the garage. You would need to go to the original GFI and place both sets of wires on the LINE terminals. Then install GFIs at the other locations, also only using the LINE terminals. I'd MUCH rather have the GFI local to where it is being used. Although, I can honestly say I have never even tripped a GFI in my home.
Agree fully. GFCIs are not expensive anymore. While code compliant to use one for several locations by running off the load side, it seems frugalness to a fault. I'd rewire the garage unit to send line voltage to bathroom and install a GFCI there. That only works if the garage to bathroom run is direct and nothing in between. Maybe it's wired that way. Failing that maybe a small label on the bathroom stating GFCI for this outlet is located in the garage.
curiousB is offline   Reply With Quote
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
Wiring Outlet from Bathroom Light-Switch TheDeputyChef Electrical 23 08-28-2013 03:56 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
ground bathroom outlet flman Electrical 4 01-16-2011 11:52 AM
outlet in bathroom cabinet OK? matty Electrical 5 08-02-2007 09:56 PM
