Gfi Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2013, 02:43 PM   #1
Gfi outlet
I just hooked up a gfi outlet in bathroom. The green light is on but outlet gives no power. The wires r hooked on the IN line screws. Everything is hooked up correct but still no power. ?? The line going to the gfi is coming from the light in the ceiling. I pushed the reset button but nothing happens. When I push the test button it does not push in at all. Could it b a bad gfi outlet I bought
ecocco1469 is offline   Reply With Quote
Old 04-18-2013, 02:57 PM   #2
Master Electrician
Rewards Points: 3,748
The wires are on the wrong terminals.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Philly Master (04-18-2013)
Old 04-18-2013, 06:14 PM   #3
Old 04-18-2013, 06:18 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
There are LINE and LOAD terminals... be sure you connected to the LINE terminals ONLY.
Old 04-18-2013, 07:56 PM   #5
I wrote that its hook up to the IN not on the load
Old 04-18-2013, 08:02 PM   #6
Was this a regular receptacle that you are now replacing with a GFCI? How many cables are coming into the box?
clydesdale is offline   Reply With Quote
Old 04-18-2013, 08:53 PM   #7
Licensed electrician
Rewards Points: 1,240
The instructions should say what the green light means.
Old 04-18-2013, 09:49 PM   #8
Master Electrician
New Levitons green light comes on immediately if power is applied to recep with line incorrectly connected to load. When line wires are correctly connected to line terminals and power is applied, green light comes on after pushing the reset button.
operagost (04-22-2013)
Old 04-18-2013, 10:05 PM   #9
There was no outlet in bathroom the wire was going to a light above sink that I removed n now hooked up to gfi.
Old 04-18-2013, 10:11 PM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Did you tap into a switch leg?
jbfan is online now   Reply With Quote
Old 04-18-2013, 11:14 PM   #11
Yes I think so. The wire is coming from the light on ceiling wich was going to another track light I above sink. So I eliminated the track light n ran wire to the new gfi outlet. I have the green light on but no power. I hooked it right black to brass in the IN line location n white to silver n hooked up ground wire. Could it b the ground wire should I try it without the ground wire
Old 04-18-2013, 11:16 PM   #12
The wires have juice cause I hooked them up to a light n it turns on. Since its coming from the switch would it b that now the white wire is the hot wire n not the black?
Old 04-19-2013, 06:38 AM   #13
Rewards Points: 311
It could be. Temporarily reverse the white and black on the receptacle. If it works, you have your answer. Go back and correct the mistake. If it doesn't work (and you are convinced you have wired it correctly), you may have a bad receptacle right out of the box.
al_smelter is offline   Reply With Quote
Old 04-21-2013, 04:18 PM   #14
The wiring was correct. The brand new outlet was bad
Outdoor Outlet seansy59 Electrical 3 03-09-2012 04:50 PM
Swithced Outlet to Ceiling Light/Fan Troubles adamiano86 Electrical 7 01-29-2012 10:36 PM
Switched outlet series Overkll Electrical 4 12-07-2010 08:38 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
Help Help richie02 Electrical 7 06-17-2008 09:42 AM
