-   -   Gfi outlet (http://www.diychatroom.com/f18/gfi-outlet-177486/)
ecocco1469 04-18-2013 01:43 PM
Gfi outlet
I just hooked up a gfi outlet in bathroom. The green light is on but outlet gives no power. The wires r hooked on the IN line screws. Everything is hooked up correct but still no power. ?? The line going to the gfi is coming from the light in the ceiling. I pushed the reset button but nothing happens. When I push the test button it does not push in at all. Could it b a bad gfi outlet I bought
brric 04-18-2013 01:57 PM
The wires are on the wrong terminals.
ecocco1469 04-18-2013 05:14 PM
I put black to hot spot ( gold) screw n white to silver screw like it said
stickboy1375 04-18-2013 05:18 PM
12 Attachment(s)
There are LINE and LOAD terminals... be sure you connected to the LINE terminals ONLY.
ecocco1469 04-18-2013 06:56 PM
I wrote that its hook up to the IN not on the load
clydesdale 04-18-2013 07:02 PM
Was this a regular receptacle that you are now replacing with a GFCI? How many cables are coming into the box?
Jim Port 04-18-2013 07:53 PM
The instructions should say what the green light means.
brric 04-18-2013 08:49 PM
New Levitons green light comes on immediately if power is applied to recep with line incorrectly connected to load. When line wires are correctly connected to line terminals and power is applied, green light comes on after pushing the reset button.
ecocco1469 04-18-2013 09:05 PM
There was no outlet in bathroom the wire was going to a light above sink that I removed n now hooked up to gfi.
jbfan 04-18-2013 09:11 PM
Did you tap into a switch leg?
ecocco1469 04-18-2013 10:14 PM
Yes I think so. The wire is coming from the light on ceiling wich was going to another track light I above sink. So I eliminated the track light n ran wire to the new gfi outlet. I have the green light on but no power. I hooked it right black to brass in the IN line location n white to silver n hooked up ground wire. Could it b the ground wire should I try it without the ground wire
ecocco1469 04-18-2013 10:16 PM
The wires have juice cause I hooked them up to a light n it turns on. Since its coming from the switch would it b that now the white wire is the hot wire n not the black?
al_smelter 04-19-2013 05:38 AM
It could be. Temporarily reverse the white and black on the receptacle. If it works, you have your answer. Go back and correct the mistake. If it doesn't work (and you are convinced you have wired it correctly), you may have a bad receptacle right out of the box.
ecocco1469 04-21-2013 03:18 PM
The wiring was correct. The brand new outlet was bad
