GFI Out Let Wont Reset - Electrical - DIY Chatroom Home Improvement Forum
Old 09-20-2007, 06:01 PM   #1
GFI out let wont reset
Hi..I have a GFI outlet in the garage, its the only outlet in there. It tripped last night and now It wont reset. I left a small car battery charger plugged into it all night by accident. I even bought a new plug and it does the same thing. I have a GFI plug in the kitchen and its OK. The main control panel is in the garage. Any Ideas would be appreciated. John
john49 is offline   Reply With Quote
Old 09-20-2007, 06:17 PM   #2
joed's Avatar
Rewards Points: 13,350
Disconnect the load connections and try to reset it. If it resets then you have a problem somewhere on the receptacles connected to the load side. Could be water in one of the outside receptacles. Could be bugs inside one of those receptacles.
Old 09-21-2007, 02:26 PM   #3
Electrician philosopher
A GFCI always---and I mean always trips for a reason. There is no such thing as a nuisance trip and if you've replaced it once youv'e eliminated a bad recp.. Be patient and troubleshoot away
Andy in ATL is offline   Reply With Quote
GFI wont reset john49 General DIY Discussions 2 09-21-2007 08:33 AM
Comfortmaker Furnace/Blower - blowing reset switch tmarcel HVAC 3 09-06-2007 09:27 AM
Kitchen outlet breaker simma Electrical 3 02-28-2007 05:50 PM
My GFI sparked and won't reset pgallardo Electrical 6 10-17-2006 12:42 PM
GFCI wouldn't reset, now it will sherlock Electrical 4 10-18-2005 10:13 AM
