GFI Needed In Garage? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-10-2009, 05:05 PM   #1
Rewards Points: 1,766
GFI needed in garage?
Adding new outlet in attached garage. Does the NEC recommend a GFI protected outlet?
bob22 is offline   Reply With Quote
Old 04-10-2009, 05:12 PM   #2
No, they REQUIRE it to meet code
Old 04-10-2009, 05:17 PM   #3
I don't appreciate the attitude in your response. I know th NEC states requirements, but as you well know (with your attitude you likely know everything) local codes can supercede NEC or they may use different year versions. My question was whether the current code REQUIRES a GFI in an attached garage.
Anyone else want to second scuby's answer?
tia,
BOb
Old 04-10-2009, 05:21 PM   #4
I have the code book, Yes they REQUIRE it
There was no tone to my post - just the facts
Old 04-10-2009, 05:36 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Are you adding on to an existing circuit? Is that circuit already GFCI protected? 15A & 20A/125V receptacles in a garage (attached or not) are required to be GFCI protected. How it's done varies.
Kyle
Old 04-10-2009, 06:42 PM   #6
dSilanskas's Avatar
Yes all outlets in a garage must be GFCI protected
dSilanskas is offline   Reply With Quote
Old 04-10-2009, 06:46 PM   #7
Bigplanz's Avatar
Rewards Points: 996
Under the 2005 code, all 'readily accessible' outlets must be GFCI protected. Under 2008, all outlets of any kind must be. 2005 made the distinction between outlets for garage door openers, refrigerators, etc. 2008 eliminated that distinction.
Bigplanz is offline   Reply With Quote
Old 04-10-2009, 07:37 PM   #8
tia,
BOb
Re-read your 1st question
Actually your question was do they recommend it
My answer was they require it
Since you fail to indicate where you are located no-one can answer about your local code
But there are very few states that have not accepted 2008
Old 04-10-2009, 08:28 PM   #9
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I ditto Scuba
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-10-2009, 09:16 PM   #10
Rewards Points: 2,350
tia,
BOb
How can you sense an attitude in a written text? Besides, your response above really doesn't make alot of sense. Your question was "Does the NEC recommend a GFI protected outlet?" You specifically asked about the NEC, not a local code. The answer you got was "No, they REQUIRE it".
You got your answer, then attacked the answerer, I do not appreciate your attitude.
Old 04-11-2009, 08:58 AM   #11
Dear Dave,
I apologize for my remark and I appreciate your help.
Hatchet buried on my part.
Bob
Old 04-11-2009, 11:09 AM   #12
Sorry my reply seemed "off", it was incomplete
No problem
Here's a link to state acceptance of 2008
http://www.childoutletsafety.org/fil...doptionMap.pdf
I think if I had a freezer in the garage under 2005 I would have run a dedicated circuit without a GFCI
To be more clear about options:
If you are adding an outlet off of an existing GFCI breaker protected circuit then a GFCI outlet is not needed
If you are adding an outlet off the LOAD side of an existing GFCI outlet then another GFCI outlet is not needed
Old 04-11-2009, 08:32 PM   #13
Bigplanz's Avatar
Rewards Points: 996
This is what I did in my basement for a freezer. I ran a dedicated outlet for the freezer, only. This is allowed (a single outlet, not a duplex) under 2005, but not 2008.
Old 04-11-2009, 08:51 PM   #14
HVAC / Plumbing
When I built my detached garage & wired it I had to install install these to meet code.. Ever tried to run power tools with these ?? They would trip every time I used my grinder , drill, etc,.. After inspection . I removed them. When/ if I sell , I may have to re install them
kenmac is offline   Reply With Quote
Old 04-11-2009, 09:24 PM   #15
I actually have been using power tools on GFCI protected outlets building my sunroom & additions for 4+ years without tripping a single one
3/8 & 1/2" drills, circ saw, 2 different table saws, sawzall, grinder
I have some lamps that my AFCI's did not like
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Garage floor repair help needed mntentman Flooring 5 08-31-2008 12:00 PM
Building Garage Loft...Advice needed mcu Building & Construction 3 08-25-2008 11:58 PM
Moving washer and dryer into Garage, perhaps some constucion needed? J187 Building & Construction 4 05-21-2008 11:53 AM
Garage Door Help Needed LaffyTaffy General DIY Discussions 7 12-17-2007 08:30 PM
