Gfi Installation Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 07-15-2009, 11:04 PM   #1
Lightbulb
gfi installation not working
I have installed a new gfi outlet according to the instructions (2) White wires on the silver connectors and (2) Black wires on the brass connectors. The ground wire is connected to the grounding terminal. The correct wiring / trip indicator light is on, but I can not get a live outlet. I have used a Electrical tester to verify a live connection and the tester does not light up or any items plugged into the outlet do not work.
Do I need to prep the gfi outlet prior to connection?
Please provide a solution or two to try to get the gfi outlet to work.
Maureen
rean102 is offline   Reply With Quote
Old 07-15-2009, 11:12 PM   #2
300zx's Avatar
Post
Did you press the Reset button?
300zx is offline   Reply With Quote
Old 07-15-2009, 11:22 PM   #3
Almost all elec. testers respond to phantom voltages. Use an incand. bulb to check for voltage at the line terminals of the GFCI.
Old 07-15-2009, 11:52 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Maureen
Maureen
You probably have it miswired. It is correct to connect the white to the silver and the black to brass but you must have the black and white that brings power to the gfci on the line terminals and the others on the load terminals if you want the downstream receptacles or lights protected by the gfci.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 07-16-2009, 01:25 AM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Stubbie,
Congrats on the annotated GFCI Pic. An annotated Pic is worth a thousand words.
Disclaimer
& Stay Safe
.....Bob Lavery
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
Inside Fan not working BenH HVAC 20 07-08-2008 07:10 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 11:27 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
