GFI Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 09-20-2011, 01:19 PM   #1
GFI installation
I installed a GFI in guest bath. There is a three way light switch downstream of GFI. Every time I turn on this light, the GFI trips. With no bulb in the light fixture, the GFI does not trip when either switch is put to on position. Will GFDI work upstream of a three way or is there inherent problem. If solution exists please advise. Is problem in grounding circuit?
Thank you.
whbare is offline   Reply With Quote
Old 09-20-2011, 02:35 PM   #2
Rewards Points: 150
Thank you.
The problem is downstream. And I would try to dedicate the outlet in the bathroom. Move the switch and light to another circuit
Sunny B. is offline   Reply With Quote
Old 09-20-2011, 03:07 PM   #3
I=E/R
a7ecorsair's Avatar
Thank you.
Technically it should work so something must be wired wrong.
I take it you removed an existing receptacle and replaced it with a GFCI. How many wires were attached to the old receptacle and how did you attach them to the GFCI?
a7ecorsair is offline   Reply With Quote
Sewage grinder pit and pump installation leff1rj Plumbing 15 02-04-2011 11:36 AM
casement windows installation versus double hung installation user82106 Building & Construction 2 06-16-2010 05:56 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 10:27 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
