GFI Electrical Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2011, 08:49 AM   #1
GFI electrical outlet
So My house was built in 74'. An electrician replaced my basebord heaters with wall heaters for floor space. They are 220v. I wanted to replace the old dark brown plugs with white ones. There is one GFI that has 2 sets of three wire coming in. After that there is a light swith and outside lights. On the exsisting GFI one of the ground wires was not hooked up and the on one of the lines coming in. I went to hook up the new GFI and thoought the ground wire should be hooked up so I twisted it around the other ground wire. The outlet or the light switch didn't work.
Problem...I forgot which ground wire wasn't used. Does it matter which one I leave out? Is it a fire hazard?. The GFI is in a box used for 2 outlets maybe like a junction.
Dan1977 is offline   Reply With Quote
Old 06-25-2011, 09:05 AM   #2
I=E/R
a7ecorsair's Avatar
Ground wires shouldn't affect the operation of a circuit. Ground wires are usually bare copper. Neutral wires have white insulation. White wires can be used in a switch circuit but have to be marked black. Knowing this, does anything change with the way you described the problem?
a7ecorsair is offline   Reply With Quote
Old 06-25-2011, 05:03 PM   #3
Lic Elect/Inspector/CPO
All the ground wires ground wires should be connected together
NJMarine is offline   Reply With Quote
The Following User Says Thank You to NJMarine For This Useful Post:
electures (06-26-2011)
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Grounded Electrical Outlet? jaymank21 Electrical 7 09-08-2010 06:40 PM
HELP Installing Fault Interrupter Electrical Outlet!!!! pancho12 Electrical 5 06-15-2010 05:38 PM
Electrical outlet phone jack extension? mikehende Electrical 3 11-28-2007 09:05 PM
Help with Electrical Outlet nsb318 Electrical 5 11-28-2007 02:10 PM
