GFI Codes For CT - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2010, 03:50 AM   #1
willwham1's Avatar
GFI codes for CT
I need to know if GFI outlets with the reset buttons are required in all new remods in baths and kitchens, not just in the panel up to 5 but on the outlet itself. thanks
willwham1 is offline   Reply With Quote
Old 04-02-2010, 07:52 AM   #2
The outlets are required to be GFCI protected
That can be a GFCI breaker & normal outlets
OR
1st outlet is GFCI & the rest are nomral outlets wired off the LOAD side of the GFCI outlet
OR
LINE power is fed to each outlet & each outlet is GFCI protected
Bedroom window egress codes drtbk4ever Remodeling 21 02-27-2013 02:21 PM
Building codes 68MHJCs Building & Construction 6 12-27-2009 12:20 PM
Fault Codes on Bosch Oven alex_ny Appliances 3 06-15-2009 07:17 PM
Electric and Plumbing Codes ClnlBrahm Building & Construction 5 09-16-2008 12:45 AM
Where to find building codes? nimblemotors General DIY Discussions 5 06-27-2008 07:15 AM
