GFI Circuit For Ungrounded Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2013, 08:51 AM   #1
Rewards Points: 202
GFI circuit for ungrounded outlet
Have some older BX cable running to some outlets in my house. I know you can use GFCI outlet for protection---can I just use a GFCI breaker to protect all of the outlets on the circuit? I know it is a little expensive, but I know the boxes get tight with the GFI outlets, may just be easier to slap a breaker in.
benleef is offline   Reply With Quote
Old 07-26-2013, 09:55 AM   #2
Licensed electrician
Rewards Points: 1,630
Either is acceptable. The breaker saves you having to find the first receptacle and you do not need to fight to fit the device in a small box.
You will still need to add the "No Equipment Ground" stickers to the receptacles.
Philly Master (07-26-2013)
connect breaker to outlet circuit or junction box naty0629 Electrical 2 05-06-2012 06:46 PM
120-V outlets and 240-V outlet on same double-pole circuit? Daneel Electrical 24 04-03-2012 11:22 PM
Open Ground in Non Daisy Chained Outlet Circuit RileyRR Electrical 2 05-18-2011 02:00 PM
Adding an outlet on a 240V circuit? Kjunk Electrical 6 05-31-2008 09:27 AM
Dead outlet and switches on otherwise live circuit viking1974 Electrical 4 08-23-2007 05:30 PM
