GFI Breaker Won't Trip With Tester - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-24-2011, 11:51 PM   #31
" Euro " electrician
frenchelectrican's Avatar
Techally wise the pole barn building do not need AFCI at all { you can leave them as optional } otherwise a standard GFCI Breaker or receptale that all you need and really I think you should remove the AFCI due some of the electric motors may kick it out.
Merci.
Marc
Old 03-25-2011, 09:46 AM   #32
Electrician
SD515's Avatar
Rewards Points: 504
Well...at least the mystery is solved
Kyle
Tags
gfi
Checking a Breaker Klawman Electrical 11 02-18-2010 07:48 PM
Why did my breaker trip? yummy mummy Electrical 24 02-17-2010 10:38 PM
GFI breaker trip troubleshooting jeeptree10 Electrical 2 06-15-2008 10:17 AM
Breaker trip troubleshooting jeeptree10 General DIY Discussions 1 06-14-2008 03:00 PM
