#16 |
Electrician
GFI Breaker Won't Trip with tester
Just throwing it out there....you are sure these are GFCI breakers and not AFCI ?
Kyle Just because you can, doesn't always mean you should |
#17 | |
GFI Breaker Won't Trip with testerQuote:
Thanks for the input. |
#18 |
I doubt that it is an AFCI. If it is an AFCI it should be installed by a qualified electrician not a do it yourselfer.
#19 |
I=E/R
GFI Breaker Won't Trip with tester |
#20 |
CodeEnforcer
#21 |
AFCI’s and their applications should only be performed by licensed electrical contractors; I would not let unlicensed persons perform these installations and I would not perform these installations myself. These applications involve working with circuit panel boxes that are electrically live even though the main circuit breakers are turned off.
#22 | |
Electrical Contractor
Don't get me wrong, I'm all about people calling me for the work, but that statement is not correct.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
| The Following User Says Thank You to jbfan For This Useful Post: | frenchelectrican (03-25-2011) |
#23 | |
#24 |
Hey there are some things I will do and I do a lot of stuff and then there are things that I wouldn’t do like playing with a panel box. Don’t get me wrong I have changed breakers, fuses and pulled all the wires to the box but that’s me. All I’m trying to say is if you’re not comfortable; call someone who knows how to do it.
#25 | |
Learning by Doing
I've done GFCIs AFCIs and regular ol' breakers. You have to be careful, but isn't that true about everything?
If I could only remember to THINK about what I was doing before I did it. |
#26 |
I’m not saying it’s illegal if you know what you are doing go right ahead and do it. After you finished, just like you said, have it inspected and signed off so you don’t have any problems down the line.
#27 |
Well the mystery is solved. AFCI breakers.
I guess when grabbed the packages I grabbed the wrong ones. Thank you for making me stop to check that. I knew it had to be something simple. |
#28 |
I=E/R
Ouch, them arc faults aren't cheap
#29 |
You can leave the arc fault breakers in and replace the first receptacle on each circuit with a gfci receptacle.
#30 |
Yep I plan on doing that. Guess I am double protected now.
At the time I bought them my cart was full of everything for lighting and outlets and switches. Spools of wire etc. Didn't even pay attention to the price I guess. Just knew I needed them. Thanks for all the input. |
| Tags |
gfi ![]() |
| Display Modes | |
| Checking a Breaker | Klawman | Electrical | 11 | 02-18-2010 08:48 PM |
| Why did my breaker trip? | yummy mummy | Electrical | 24 | 02-17-2010 11:38 PM |
| GFI breaker trip troubleshooting | jeeptree10 | Electrical | 2 | 06-15-2008 11:17 AM |
| Breaker trip troubleshooting | jeeptree10 | General Discussion | 1 | 06-14-2008 04:00 PM |
