GFI Breaker Protect GFI Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2012, 12:16 PM   #1
GFI breaker protect GFI outlet
Installed single GFI outlet for sprinklers, Is a GFI breaker required for that outlet ? Type 3r enclosure source for power on edge of back porch has existing 2 pole GFI 50a breaker for hot tub
graynavy is offline   Reply With Quote
Old 05-29-2012, 12:18 PM   #2
Rewards Points: 6,652
You do not need both, only one. And also can not use the 50 amp for the hot tub, unless you have gotten rid of the tub, then you would have to make sure that you have two hots, a neutral and a ground, for a proper 120vac sub-panel.
Old 05-29-2012, 12:19 PM   #3
i know NEC code has changed Alot, out of contact since 2006, no longer in trade as to physical limitations
Old 05-29-2012, 12:25 PM   #4
did not give full content as to enclosure, panel has two remaining slots for single breakers WILL NOT TRY TO PIGGY BACK !!!CIRCUITS----unable to locate EATON/CH breaker without GFI tail neutral
Outlet causes breaker to trip when something is plugged into it. yama450yfz Electrical 4 08-11-2011 06:42 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Circuit Breaker trips when I plug into an outlet Alex in Orlando Electrical 3 09-05-2010 01:04 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Kitchen outlet breaker simma Electrical 3 02-28-2007 05:50 PM
