Gfi Breaker Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 12:38 AM   #1
gfi breaker not working
Sorry to post this again, but I'm wondering if my breaker is broken or if my wires are wack. Is there a way to find out which one is broken? The breaker isn't tripping or anything. and if I were to replace the breaker, would I have to purchase a GFI breaker or would a normal breaker work?
Thank you
kk1234 is offline   Reply With Quote
Old 01-08-2012, 01:12 AM   #2
Julius793's Avatar
Thank you
What about it isn't working? As to replacing it my guess is it's gfi for a reason and you will need an other gfi to replace it with.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-08-2012, 01:30 AM   #3
dmxtothemax's Avatar
Rewards Points: 5,096
DITTO !
What is wrong ?
What isnt working ?
Why do you want to replace the breaker ?
dmxtothemax is offline   Reply With Quote
Old 01-08-2012, 02:20 AM   #4
jproffer's Avatar
Rewards Points: 702
If this means that it's not tripping when it should...or when tested.....
Do you have the neutral pigtail connected to the neutral bar?
jproffer is offline   Reply With Quote
Old 01-08-2012, 02:32 AM   #5
When did it not trip ?
when you thought it should have ?
Under what circumstances ?
It is important !
Old 01-14-2012, 02:25 AM   #6
The problem is that there is absolutely no electricity going through it and I don't know if the problem is the breaker or the wires.
Old 01-14-2012, 11:58 AM   #7
Julius793's Avatar
Well is it a gfi breaker or a gfi outlet?
Did you try resetting it?
Next would be to open it and test for power let us know what you find.
Old 01-14-2012, 12:10 PM   #8
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Julius793 View Post
Well is it a gfi breaker or a gfi outlet? <-- good Q
Did you try resetting it?<-- good Q
er... If a question indicates the OP has already opened their panel
(or light fixture or switch J box) or volunteered that they're willing to... yeah sure.
But is it advisable to advise anyone to open their panel?
Especially when they've not shown much of a clue else wise?
Old 01-14-2012, 12:20 PM   #9
Julius793's Avatar
You do have a good point but that's why there's a warning at the top of every page
Old 01-15-2012, 11:32 PM   #10
It is a GFI breaker that says "test" on it. I've already opened it and tested it with a voltage tester and there is no power.
Old 01-16-2012, 12:00 AM   #11
Licensed electrician
Rewards Points: 1,020
Turn the breaker off and then on. Do you have power now?
Old 01-21-2012, 02:55 PM   #12
No, I don't have power.
Old 01-21-2012, 02:56 PM   #13
What I'm wondering if that if I need to buy a new breaker, does it have to be one with a "Test" button on it? Also, it has a wire attached to the breaker, I assume that it is a ground wire.
Old 01-21-2012, 02:58 PM   #14
Julius793's Avatar
If its a gfi it will have the test button and no it's a neutral wire not a ground
Old 01-21-2012, 03:01 PM   #15
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Don't make assumptions in electrical work.
A gfci breaker has a wire that connects to the neutral bar, and the circuit neutral connects to the breakers, as well as the hot.
Remove the hot wire from the breaker, reset then test the screw.
Circuit stopped working, breaker did not trip nr5667 Electrical 7 07-08-2012 04:31 AM
running a subpanel from the main breaker on the pole. shocknawe Electrical 6 05-09-2011 10:51 AM
Heat Pump trips breaker gt1935 HVAC 2 03-26-2011 11:06 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Breaker problem jdhar Electrical 11 06-10-2009 02:18 AM
