Old 03-13-2011, 01:32 PM   #1
gfi breaker or gfi dead front
Faceless GFCI or GFCI Breaker? installing an air tub in upstairs bathroom in normal tub space, should i use a gfi breaker or dead front gfi? what would you use if you had a choice? i know a dead front would be convienent if it trips, but if its installed right, it shouldnt really trip that much so a breaker would be good as well. if using dead front where should it be located? not under skirt of course.
i can do it is offline   Reply With Quote
Old 03-13-2011, 01:41 PM   #2
J. V.'s Avatar
Whats a dead front?
Old 03-13-2011, 01:49 PM   #3
sorry, faceless gfci or blank front gfci . i was reading another post and they called it a dead front gfci, it was stuck in my head, somone gave the same answer you did lol.
Old 03-13-2011, 02:27 PM   #4
Licensed electrician
The deadfront GFI will be about 1/3 the cost of a GFI breaker.
Old 03-13-2011, 06:52 PM   #5
Semi-Pro Electro-Geek
I'd install a dead front GFCI on a wall nearby. It's cheaper than a GFCI breaker, and more convenient to reset.
mpoulton is offline   Reply With Quote
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Trying to revive dead lawn... deevahs Landscaping & Lawn Care 2 05-13-2010 01:34 PM
phantom breaker mihamih Electrical 5 01-13-2010 07:38 PM
900W and up trips breaker, Circuit draws power even with everything off... jasonblu Electrical 40 12-09-2009 03:29 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
