-   -   GFI breaker (http://www.diychatroom.com/f18/gfi-breaker-170655/)
Huskyfan68 01-31-2013 01:06 PM
GFI breaker
After a bad night of storms in NJ (wind) this morning we had no power in any of my bathrooms.... Looks like all 2.5 bathrooms (basically and outlet and a light in each) are tied into one GFI breaker in the panel- I tried to reset it several times and it keeps tripping. Could it be that the breaker itself is shot or is there something else to look for? (nothing is plugged into any of the outlets....)
Daltex 01-31-2013 01:17 PM
Could be lots of things but I'll get you started with the most obvious to me: Check the breaker panel to see if the breaker tripped. Some newer GFCI's need power to reset. If you are getting power to the receptical then I would replace the GFCI as they can wear down over time. The lightning surge may have taken it out.
Edit: Didn't catch it was the GFCI breaker. Was thinking receptical. That said I'd remove the hot and neutral and ohm it out to see if you are getting any short between the lines. As stated below it could be rain in an exterior outlet.
Jim Port 01-31-2013 01:41 PM
Wind driven rain may have gotten into an exterior receptacle.
