Old 10-22-2008, 04:50 AM   #1
Gfi
Is a GFI receptacle voltage sensitive, as in will it provide any protection when fed via a dimmer?
Gary
garyoutwest is offline   Reply With Quote
Old 10-22-2008, 05:22 AM   #2
the Musigician
DangerMouse's Avatar
Gfi
gfci and dimmers to not tend to get along well at all.....
DM
Old 10-22-2008, 08:22 AM   #3
Gfi
Outlets and dimmers are NOT suppose to mix.
rgsgww is offline   Reply With Quote
Old 10-22-2008, 09:19 AM   #4
Electrical Contractor
Gfi
Right On!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 10-22-2008, 12:52 PM   #5
Gfi
As far as standard receptacles go, this is correct; however, there is a special receptacle available that can be dimmed and still comply with the NEC. This receptacle will not accept a standard plug. The lamp that plugs into it must have its plug replaced with a special plug that will fit the dimmed receptacle.
http://www.lutron.com/applicationnotes/048085a.pdf
Matsukaze is offline   Reply With Quote
