Old 10-16-2010, 02:26 PM   #1
GFCI will not reset.
I have 2 GFCI outlets outdoors that will not reset. The 2 bathroom outlets are on this circuit also and so do not work. They were all working fine until a storm came through with a lot of lightning. The circuit breaker in the panel did not trip. A GFCI outlet tester indicates no hot wire connections but the wires are connected and done so correctly. The system worked fine until the storm. Could a surge from a lightning strike have caused the GFCI outlet internal circuit to go bad?
mrdaver is offline   Reply With Quote
Old 10-16-2010, 02:34 PM   #2
get a voltmetter and a noncontact voltage tester.check power at breaker.if ok start opening boxes and trouble shoot.might be best to call an electrician...
oleguy74 is offline   Reply With Quote
Old 10-16-2010, 02:49 PM   #3
Gfi receptacles have a M.O.V. built into their electronic circuits which will open on a surge.
bobelectric is offline   Reply With Quote
Old 10-16-2010, 11:28 PM   #4
try replacing the GFCI outlet. i had a two week old GFCI go bad back in June, would not reset. i went through the whole list of trouble shooting, but everything was right. so i replaced the outlet, and everything worked again. no problems with that location since then.
1910NE is offline   Reply With Quote
My GFCI doesn't reset QUADCO Electrical 4 09-20-2010 10:23 PM
GFCI Breaker won't reset secutanudu Electrical 6 09-12-2010 03:41 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
Kitchen outlet breaker simma Electrical 3 02-28-2007 06:50 PM
GFCI wouldn't reset, now it will sherlock Electrical 4 10-18-2005 11:13 AM
