GFCI Will Not Protect Five Outlets - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 06-14-2013, 04:39 PM   #61
Rewards Points: 119
Originally Posted by Oso954 View Post
So, are you trying to put the fire out, or fanning the flames ?
I tried putting the fire out once with the picture of the circuitry and was told that I was a dumb a$$ that is not how they worked.
A number of them try to justify removing GFCI from there yards by saying that they do not need them since christmas lights do not have a ground.
KStatefan is offline   Reply With Quote
Old 06-14-2013, 04:56 PM   #62
Licensed Pro
Originally Posted by KStatefan
I had never seen this circuitry before. Next time GFCI comes up on a Christmas light forum I belong to I will post this diagram.
This is how I have always seen the circuit.
That's a valid diagram. The N-G monitoring is part of that box labelled "solid state circuitry". Check out the link Oso has up.
Old 06-14-2013, 05:02 PM   #63
dmxtothemax's Avatar
Rewards Points: 5,188
Originally Posted by k_buz View Post
There is alot of misinformation in this thread. I was going to respond to DMX's post, but it is so full of wrong I didn't know where to start. Just ignore his post.
Please feel free to say where you think I am wrong ?
I dont think I am wrong,
but the terminology is slightly different in the USA to Australia,
so you might just be mis-understanding what I am trying to say.
dmxtothemax is offline   Reply With Quote
Old 06-14-2013, 05:14 PM   #64
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,524
House Helper.... I'll check next time I'm picking up some GFI's... but is this GFI (the n-g fault moitoring GFIfor lack of better name) the common, likely,normal type that I'm most likely to pick up today in a big-box.
That was really interesting what you taught several of us.
Best
MTN REMODEL LLC is online now   Reply With Quote
Old 06-14-2013, 08:10 PM   #65
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Idiots...
Old 06-14-2013, 09:01 PM   #66
Electrical Enthusiast
Rewards Points: 504
Yeah because obviously you won't get shocked if there's no ground wire.
Kyle_in_rure is offline   Reply With Quote
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
sirsparksalot (06-14-2013)
Old 06-14-2013, 11:46 PM   #67
Rewards Points: 512
Originally Posted by stickboy1375 View Post
Idiots...
I resemble that remark.
Installation is the Reverse of Removal.
The Following User Says Thank You to sirsparksalot For This Useful Post:
MTN REMODEL LLC (06-15-2013)
Old 06-15-2013, 12:38 AM   #68
Rewards Points: 504
GFCI Outlets Needed jdjd Electrical 2 05-08-2012 03:57 PM
Low-voltage track light triggers GFCI outlets mpf01 Electrical 4 11-08-2011 09:15 PM
GFCI Outlets in Series allbymyself Electrical 6 01-24-2011 11:52 PM
GFCI breakers equivalent to GFCI outlets? Any code pitfalls? TomServo Electrical 27 02-04-2010 10:59 PM
Add GFCI at panel to protect outside Red Squirrel Electrical 3 12-18-2009 09:18 PM
