GFCI Will Not Protect Five Outlets - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-14-2013, 08:04 AM   #31
Licensed Pro
Originally Posted by k_buz
There is alot of misinformation in this thread. I was going to respond to DMX's post, but it is so full of wrong I didn't know where to start. Just ignore his post.
HH, a GFI will function (trip) without a grounding conductor (ground). It will not function without a groundED conductor (neutral). This is the reason one of the acceptable methods of replacing a receptacle on an ungrounded circuit is to use a GFCI.
I understand that. My last answer was in response to tripping on a neutral/ground short... that relies on the ground connection to the panel, so a bootleg ground will not trip the GFCI.
Old 06-14-2013, 08:06 AM   #32
Licensed Pro
Originally Posted by joed
I would like to know how you induce a small current on the neutral without using any current from the hot.
You do it from the line side of the GFCI, before the sensor.
Old 06-14-2013, 08:52 AM   #33
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,476
Thanks Joed....Good question....I'm still "scatchin my head on this"
MTN REMODEL LLC is online now   Reply With Quote
Old 06-14-2013, 09:09 AM   #34
House Helper... Sorry to be so dense/slow understanding this 120 HZ circuitry that I never knew was in a GFI.
Is it just a duplicative type check by the GFI that there is not a hot ground on the load side performed prior to any load being placed on the load side...
Because if you have a hot ground (neutral- ground "short"/ jump/ connection) on the load side, the GFI is going to trip anyway as soon as a load is placed on the load side..... so is it not just a duplicative type double check.
Am I still confused or missing something.... THANKS for hanging/explaining to me.
Best
Peter
Old 06-14-2013, 09:31 AM   #35
Electrical Enthusiast
Rewards Points: 504
Next topic: how an AFCI works!
Kyle_in_rure is offline   Reply With Quote
Old 06-14-2013, 09:55 AM   #36
jproffer's Avatar
Rewards Points: 706
The same only at 30 mA instead of 6
(For the record, I haven't got the slightest idea HOW an AFCI or a GFCI works...it was a joke)
jproffer is online now   Reply With Quote
Old 06-14-2013, 09:58 AM   #37
Rewards Points: 1,622
What is a "bootleg" ground?
miamicuse is offline   Reply With Quote
Old 06-14-2013, 10:02 AM   #38
Sorry Guys... I just never heard of that 120 HZ circuitry in a GFI, and just trying to understand it.
Matter of fact, I've got to learn about AFCI too,
Peter
Old 06-14-2013, 10:04 AM   #39
Often in no ground wiring, a jumper from neutral to the ground in a receptical, or to any grounding type wire to the metal box or appliance ground.(EDIT2:Sometimes also happens when someone looses a neutral and someone has jumped the broken neutral to the ground)
EDIT: Thought I otta add, gives you a hot ground and "hot appliance" and potential shock issue to the user.
Old 06-14-2013, 10:26 AM   #40
jproffer's Avatar
Rewards Points: 706
Peter
Don't be sorry to me ....that was aimed at the post I quoted...and I was just messing around.
But I do think I got the numbers right...an AFCI trips at 30 milliamps difference, and a GFCI trips at 6 milliamps difference.
The Following 2 Users Say Thank You to jproffer For This Useful Post:
Kyle_in_rure (06-14-2013), MTN REMODEL LLC (06-14-2013)
Old 06-14-2013, 11:54 AM   #41
Rewards Points: 119
Peter
I have not either.
What voltage is this 120 HZ current?
KStatefan is offline   Reply With Quote
Old 06-14-2013, 12:12 PM   #42
joed's Avatar
Rewards Points: 12,424
I don't believe the explanation is true that is why I asked the question pretty much proves I am correct.
The GFCI function is simple. If there is a difference in current between hot and neutral it trips. I have not heard of any other features that would trip it except that some of them will not reset if there is no power present.
Old 06-14-2013, 12:18 PM   #43
Joed.... I'm a wondering too and "scratchin my head" on this one
Best
Peter
Old 06-14-2013, 12:30 PM   #44
Resi EC
Rewards Points: 252
Its where someone takes a wire and jumps from the white wire terminal, and ties it to the ground screw, completely illegal and dangerous
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Old 06-14-2013, 01:16 PM   #45
Oso954's Avatar
Rewards Points: 1,010
No, it doesn't.
Oso954 is offline   Reply With Quote
GFCI Outlets Needed jdjd Electrical 2 05-08-2012 03:57 PM
Low-voltage track light triggers GFCI outlets mpf01 Electrical 4 11-08-2011 09:15 PM
GFCI Outlets in Series allbymyself Electrical 6 01-24-2011 11:52 PM
GFCI breakers equivalent to GFCI outlets? Any code pitfalls? TomServo Electrical 27 02-04-2010 10:59 PM
Add GFCI at panel to protect outside Red Squirrel Electrical 3 12-18-2009 09:18 PM
