GFCI Will Not Protect Five Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2013, 11:29 PM   #1
GFCI will not protect five outlets
I have installed many GFCI outlets and wired them to protect down line outlets. I am helping a neighbor by installing one in his storage building. There are five wall mounted outlets. I installed the GFCI in the first one and fed the rest from the "load" side. The reset button will not stay in. I even substituted another GFCI. Same problem. When I disconnect the hot and neutral from the load side I am able to operate the reset button.
Your ideas are welcome.
Thank you,
Dale
radiodale is offline   Reply With Quote
Old 06-10-2013, 11:56 PM   #2
jproffer's Avatar
Rewards Points: 706
Then there is a fault downstream. A GFI should protect 5 receptacles with no problem.
jproffer is offline   Reply With Quote
The Following User Says Thank You to jproffer For This Useful Post:
jbfan (06-11-2013)
Old 06-10-2013, 11:56 PM   #3
Rewards Points: 512
There's a problem down stream? Do the downstream receptacle work without the GFCI in the first receptacle? Put the regular recep. back in and check those.
Installation is the Reverse of Removal.
Old 06-11-2013, 12:13 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Check the rest of the receptals downstream and double check the netural / ground it should not be touching each other.
It easy to check all of them at once then you will know you got it otherwise it can be a easter egg hunt.
Merci,
Marc
Old 06-11-2013, 12:14 AM   #5
Rewards Points: 328
possible ground and neutral making contact on load side.
oleguy74 is offline   Reply With Quote
Old 06-11-2013, 02:05 AM   #6
Rewards Points: 4,792
That's the only thing that makes sense.
jeffnc is offline   Reply With Quote
Old 06-11-2013, 08:34 AM   #7
Rewards Points: 13,300
Powers on when your trying to reset it?
Old 06-11-2013, 08:40 AM   #8
Rewards Points: 2,516
Originally Posted by radiodale View Post
The reset button will not stay in.Your ideas are welcome.
My idea because it happened to me was when you pushed one of the protected receptacles back in the the box some of the insulation was scraped off the wire and is making contact with something it should not be making contact with.
hammerlane is offline   Reply With Quote
Old 06-11-2013, 08:52 AM   #9
Licensed electrician
Rewards Points: 1,296
Split the wires at the 3rd box. Reconnect the GFI and see if it works. If yes, the problem is in box 4 or 5. If no, the problem is in the first 3 boxes.
Old 06-11-2013, 09:40 PM   #10
dmxtothemax's Avatar
Rewards Points: 5,108
Thank you,
Dale
For GFCI's to work properly,
It's important that the earth and neutral lines are sperate,
And both go back to the main panel as seperate lines.
There should also not be any extra earths, apart from the
one and only main one at the panel.
dmxtothemax is offline   Reply With Quote
Old 06-11-2013, 09:43 PM   #11
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
What the wires do before the GFI does not matter. Most ground and neutral wires go to the same bar in the panel.
The Following User Says Thank You to k_buz For This Useful Post:
MTN REMODEL LLC (06-12-2013)
Old 06-12-2013, 04:21 AM   #12
Why? A GFCI circuit doesn't know where the current goes after it leaves the circuit. It couldn't possibly tell if the ground and neutral are connected after the circuit. A GFCI circuit only knows if the current going into it equals the current going out of it.
Old 06-12-2013, 06:40 AM   #13
Are you talking about before or after the gfci ?
Old 06-12-2013, 08:23 AM   #14
By "circuit" I mean the GFCI circuitry.
Old 06-12-2013, 09:12 AM   #15
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 4,652
It does not matter to the GFI what happens upstream from it.
MTN REMODEL LLC is offline   Reply With Quote
GFCI Outlets Needed jdjd Electrical 2 05-08-2012 04:57 PM
Low-voltage track light triggers GFCI outlets mpf01 Electrical 4 11-08-2011 10:15 PM
GFCI Outlets in Series allbymyself Electrical 6 01-25-2011 12:52 AM
GFCI breakers equivalent to GFCI outlets? Any code pitfalls? TomServo Electrical 27 02-04-2010 11:59 PM
Add GFCI at panel to protect outside Red Squirrel Electrical 3 12-18-2009 10:18 PM
