GFCI - White & Black Both HOT? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2012, 08:38 PM   #1
Rewards Points: 37
Trying to repair/replace GFCI on a kitchen island.
Standard 2-wire coming into the GFCI, but BOTH the white & black wires are HOT......obviously, the GFCI is not working.
Tried to troubleshoot a little....found that other receptacle (dining room) on the same circuit has incoming and outgoing 2-wire and ALL 4 wires (2 black, 2 white) are HOT.
There is one other GFCI (in the dining room) on the same circuit that is working....however, when I remove the black wire from the LOAD side, all of the same wires on the other 2 outlets (GFCI & the Standard) are still ALL HOT.
Neither the GFCI or the standard receptacle are working.
Note: the kitchen island has two GFCIs....the other one is working.
The one GFCI on the island (not working) and the other 2 receptacles mentioned (GFCI in the dining room & Standard in the dining room) are on one circuit.....however, when I shut the breaker for the other GFCI on the island (that is working), this also shuts off the GFCI in the dining room that is working & is also on the same circuit as the other GFCI in the island that's not working....?
Please help...thanks in advance!
hagler is offline   Reply With Quote
Old 03-16-2012, 08:45 PM   #2
Missouri Bound's Avatar
Hot? Did you use a tester? What do you consider hot? Power going through a white wire doesn't make it a hot wire, just means that it is part of an energized circuit.
Do you want it your way or the right way?
Old 03-16-2012, 08:46 PM   #3
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
What kind of tester are you using to verify the wires are hot?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-16-2012, 10:09 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Is each of the wires showing 120v to the ground wire?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 03-17-2012, 10:04 AM   #5
Rewards Points: 37
Yes...Each of the wires going to the GFCI are showing 120v to the ground wire.
I just used a volt tester and tested each wire/screw to ground.
Same thing for the outlet in the dining room...all wires are 120v to the ground wire.
Should I trace the wires coming into the GFCI using a resistance test? Then I can know where the wires are coming from?
What to do next?
Thanks for the help.
Old 03-17-2012, 10:12 AM   #6
rrolleston's Avatar
Sounds like something is wired wrong in a box somewhere or maybe in your panel. What do you get when you test between the hot and neutral.
Old 03-17-2012, 11:08 AM   #7
joed's Avatar
Rewards Points: 12,016
That is the symptom of an open neutral.
Old 03-17-2012, 12:01 PM   #8
kbsparky's Avatar
With a load imposed.
Or a high-impedance input digital meter that is reading phantom voltage on disconnected lines ... (GFCIs disconnect both the hot and neutral when tripped)
-KB
Old 03-17-2012, 04:17 PM   #9
Rewards Points: 37
Just tested both the GFCI and the outlet in the dining room...both look like they have an open neutral.
When I tested between hot and neutral nothing registered...same on both.
How do I go about fixing an open neutral?
Old 03-17-2012, 04:33 PM   #10
Pure Genius
Rewards Points: 150
Gotta find where its open. Shut off your breaker and see what else goes off. Start testing those devices
Dierte is offline   Reply With Quote
Old 03-17-2012, 06:41 PM   #11
joed's Avatar
Look in the nearest working box on the same circuit. If it's not there then keep looking in other boxes on the circuit.
Old 03-19-2012, 09:29 AM   #12
Rewards Points: 37
Found the loose neutral connection in nearest working box - problem solved.
Thanks for all of the help - this forum has been great.
Simple (?) line/load question: 3 wires (2 black, 1 white) for 2 spots Local Dimwit Electrical 3 07-13-2011 11:26 AM
Wiring new lights in garage Question Tyus4 Electrical 92 02-14-2011 12:46 AM
black, white, white, black! bamaranch General DIY Discussions 5 07-04-2010 01:24 PM
Black & White kitchen questions TraGregZ Remodeling 4 01-06-2010 12:34 PM
Black White and Red CTH Electrical 6 04-02-2008 12:46 AM
