GFCI Wearing Out? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 04:04 PM   #1
Rewards Points: 111
GFCI wearing out?
I have a GFCI outlet in our bathroom that was recently remodeled. The outlet is new, and over the last 6 months, it has seen constant daily use from my wife and i plugging in and removing things (hair dryer, electric razor, etc).
It seems like the plug gets harder and harder to push in/remove as time goes on, like there is more resistance. I havent had this issue before, but do outlets corrode or wear out?
a) is it a problem b)is there a solution other than replacing the outlet?
redline9k is offline   Reply With Quote
Old 11-28-2011, 04:18 PM   #2
Rewards Points: 6,652
Possible cheap GFCI. Replace with commercial grade (ie Leviton Pro series).
Old 11-28-2011, 06:41 PM   #3
Licensed electrician
Rewards Points: 1,778
Receptacles can degrade over time, but 6 months seems excessive. Typically they would loose the spring tension and become looser, not tighter.
Perhaps the device is not mounted tightly to the box.
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
GFCI troubleshooting XwpisONOMA Electrical 20 11-13-2011 05:19 PM
Pond pumps tripping GFCI lendosky Electrical 23 12-23-2010 03:22 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
