GFCI & Undersink Water Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 07-04-2013, 12:00 AM   #1
Rewards Points: 446
GFCI & undersink water heater
Small instantaneous water heater in cabinet under sink. Install instructions call for a GFCI breaker.
Searching the code I can't find a reference that would require this. It's a 220V 4Kw.
old_squid is offline   Reply With Quote
Old 07-04-2013, 01:19 AM   #2
Rewards Points: 6,652
If the instructions state that you need a GFCI outlet or breaker, you need to follow what they state. If my calculation is correct, it needs a 20 amp breaker per leg, or 20 amp double pole GFCI breaker. Pretty expensive breaker when you start pricing them out.
Old 07-04-2013, 07:24 AM   #3
Resi EC
Rewards Points: 252
delete
misread OP
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Old 07-04-2013, 07:47 AM   #4
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Originally Posted by old_squid View Post
searching the code i can't find a reference that would require this. It's a 220v 4kw.
110.3(b)
wirenut1110 is offline   Reply With Quote
The Following 5 Users Say Thank You to wirenut1110 For This Useful Post:
frenchelectrican (07-06-2013), gregzoll (07-04-2013), k_buz (07-04-2013), old_squid (07-06-2013), Speedy Petey (07-06-2013)
Old 07-06-2013, 12:16 PM   #5
Rewards Points: 446
Thanks. Never fails....... search the code for specifics without looking for the general "catch all" rules.
Old 07-06-2013, 01:11 PM   #6
You can go to the NFPA.org site and pull up the NEC. Your local city or village should have the info online.
Now of course, there are some of us with the electronic version of the NEC, but due to NFPA reg's we just cannot send it to someone, but we can pull cites out of it for people, if need.
The rules are in the manual most of the time, that comes with the device, but it is getting to the point that they just give you the Chapter, Section, sub-section, since you are able to search for it online, by using the following in any search engine for example.: NEC 110.3(b)
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 09:48 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
