Gfci Trips - Electrical - DIY Chatroom Home Improvement Forum
Old 05-11-2012, 02:00 PM   #1
Gfci trips
Gfci trips when adding another outlet
Corpsol is offline   Reply With Quote
Old 05-11-2012, 02:23 PM   #2
kevinp22's Avatar
Rewards Points: 252
I assume you mean a GFCI receptacle and you installed this new receptacle (outlet is more generic than receptacle, I assume you mean receptacle) on the "load side" of this gfci that is tripping?
What else is downstream/load side of the gfci? Does it trip immediately or is there a delay?
Check the connections in both locations. It only takes 5ma of current to trip a gfci so any ground leakage will trip it
Kevin
kevinp22 is offline   Reply With Quote
GFCI trips when light switch is turned off technicholas Electrical 6 01-02-2012 10:26 AM
GFCI breaker trips wth fluorescent light DexterII Electrical 0 11-22-2011 09:01 AM
GFCI trips at the same time ATJaguarX Electrical 84 10-22-2011 10:23 PM
New Fluorescent Ballast trips GFCI Breaker?? marc515 Electrical 7 02-18-2010 04:42 PM
GFCI intermittent nuisance trips jejm1975 Electrical 43 09-07-2008 09:18 AM
