Gfci Tripped By Waffle Iron - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2012, 11:21 AM   #1
gfci tripped by waffle iron
I tried to use my waffle iron but its shutting off all of my gfci outlets in my kitchen, everything else that i plug in to the same outlet works fine, does this just mean that the waffle iron is fried? i havent used it in a few years but it worked just fine then. thanks
Peachy K is offline   Reply With Quote
Old 08-22-2012, 11:24 AM   #2
kevinp22's Avatar
Rewards Points: 252
yes. its time for a new waffle iron. the gfcis did what they are supposed to do and protected someone from shock
kevinp22 is offline   Reply With Quote
The Following 2 Users Say Thank You to kevinp22 For This Useful Post:
jbfan (08-22-2012), Peachy K (08-22-2012)
Old 08-22-2012, 11:45 AM   #3
Rewards Points: 105
Your waffle iron probably has a short to the case from a wire that has had the insulaton rubbed or worn. If it is tripping the GFCI and not the breaker is the telltale sign.
Bugman1400 is offline   Reply With Quote
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 10:43 AM
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 08:43 AM
Why is GFCI being tripped? bcfallar Electrical 13 07-21-2011 07:45 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI receptacle gets tripped by hallway light proofer Electrical 10 03-17-2008 07:29 PM
