GFCI Trip Form Fridge - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-04-2009, 03:26 PM   #16
Rewards Points: 820
Actually, it is not recommended to place refrigerators or freezers on a GFCI.
Not sure what you do if one is located in an unfinished basement, where GFCI is required for all receptacles.
I think I would probably go with the GFCI, and a power-failure alarm that is loud enough to hear from upstairs.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 02-04-2009, 04:25 PM   #17
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by Stubbie View Post
So your splitting the multiwire and not sharing the neutrl after the JB??
Right now, it is a single circuit, sitting on a double pole breaker, with nothing but a wire nut on the wire that runs from the other pole on the breaker.
I am sorry I didn't explain it well. The plan is to use the other leg of the multiwire elsewhere via the jbox, but for now, the hot is capped and I have not cut and pig tailed the neutral yet.
The fridge outlet right now is 12awg thhn red via conduit direct run to panel via emt, and 1 white neutral via the same conduit. The THHN comes into the 4x4 that this GFCI is in and is pigtailed to this GFCI, and to a piece of romex that feeds 1 other outlet and a outside light. The outside light and other outlet worked fine prior to pluging in the fridge.
There is nothing on the load side of the outlet, and the hot and neutral are deffiatly connected in the proper places.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-04-2009, 04:26 PM   #18
DIY'er
jamiedolan's Avatar
FW
Unfinished basement. May have to use a dedicated appliance outlet for it. Jamie
Old 02-04-2009, 04:29 PM   #19
DIY'er
jamiedolan's Avatar
Update
The fridge ran for quite a while over night and I assume into the day today. It triped the P&S GFCI sometime today, the fridge is still kind of cold, so I don't think it was too long ago.
The P&S is brand new. I found the date on the fridge, it was made in 01/ 1998. 11 years old...
Should I just forget it, install a dedicated outlet and move on? I just put a 1/2" setoff via a KO to a handy box and install a single plug unless anyone has any better ideas...
Thanks for all the help.
Jamie
Old 02-04-2009, 04:40 PM   #20
DIYer
What I did was put the freezer on the first outlet in the circuit, unprotected by a GFCI, and made that a single non-duplex outlet. Then the circuit continued on to a GFCI and all the rest downstream were GFCI protected.
This way only the freezer outlet was without GFCI protection but I also didn't need a fully dedicated circuit. Worked for me.
Gigs is offline   Reply With Quote
Old 02-04-2009, 07:31 PM   #21
Rewards Points: 820
Sorry about that. I forgot about the exception for the single appliance receptacle.
That's what I'm going to need if the washer trips the GFCI I am going to install in the next few days.
I'll have to install two single receptacles, one for the washer, the other for the dryer. Can't use a duplex, because of the plugs on both appliances come out facing down.
If I do that, can I put both single receptacles on the same 20A branch?
FW
Old 02-04-2009, 07:32 PM   #22
Rewards Points: 820
Jamie
You might have leakage from the fridge. Maybe it's time to replace it, although I would think 11 years isn't old for a fridge. I've got one that's 35 years old, but not on a GFCI (finished basement). I wonder what might happen if I plug it into the GFCI...
FW
Old 02-04-2009, 07:46 PM   #23
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
It would seem it certainly is a problem with the fridge. You would be allowed to not gfci it under 2005 or before code cycles depending on it's location...ie not close to a sink. Moisture getting on the terminal block, if you will, where the power cord is terminated could be tripping the gfci. Condensation can do it also...just some things to check.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-04-2009, 08:49 PM   #24
Rewards Points: 820
Anyone know why fridges are not grounded (double-insulated instead) when window AC are all required to have an EGC?
When I was a kid, we had a fridge that had its chassis unknowingly connected to line, and if someone touched its handle, and the nearby steam pipe... zap. Full 115V electrocution, although no one was seriously injured.
I was way too young to understand electricity, and my parents didn't have a clue. They just wrapped the handle of the refrig with electrical tape and we all knew never to touch the fridge and the pipe at the same time.
Once, a friend was nearly electrocuted, but someone had the sense to give her a shove to get her off.
If only we had GFCI's back then.
FW
Old 02-04-2009, 09:26 PM   #25
DIYer
FW
If you had GFCIs back then I'm sure your parents would have bypassed it heh. 120v is unlikely to kill you, but it's not impossible. If you hit the right combo of circumstances it can get you.
Old 02-04-2009, 09:28 PM   #26
Rewards Points: 820
Or, when I got older I might have attached an EGC to the faulty fridge and blown the fuse. Then they (my parents) would have banished me from ever playing with electricity again<g>
Old 02-05-2009, 01:16 AM   #27
DIY'er
jamiedolan's Avatar
I'm going to take a quick look at the fridge and see if I can verify it's connections. I'll check the humidity level, it is about 20' from the laundry room, but it is heating season here, and it is pretty dry in general.
Guess it is just a fridge problem. Does this imply the fridge is dangerous? (i.e. that it may be leaking current to the metal frame).
Jamie
Old 02-05-2009, 10:58 AM   #28
DIYer
Jamie
If it only happens when the motor first starts up, i.e. when you first plug it in, and never later on, then it could be a false trip. GFCIs usually aren't wrong though. They have a pretty simple job to do and they normally do it well.
Old 02-05-2009, 07:11 PM   #29
Rewards Points: 820
You know what Chris75 would say about "false GFCI trips", but we won't wake him, will we<g>
FW
Old 02-05-2009, 07:16 PM   #30
False trips?
They do trip for a reason...don't know what your talking about
rgsgww is offline   Reply With Quote
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
Gfci Stays Trip CAJUN_MAN Electrical 6 12-14-2007 12:49 PM
GFCI questions 5circles Electrical 4 11-05-2007 09:24 PM
GFCI outlet vs. breaker - GF trip speed LanterDan Electrical 2 01-09-2007 07:05 AM
