GFCI Switch. With Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2012, 11:36 AM   #1
GFCI switch. With outlet
We recently purchased a foreclosed home. We need an occupancy inspection beside we can gain occupancy. In the bathroom there is no outlet so I purchased GFCI with a switch and outlet. My question is can we hook both the light and exhaust fan together to come on together? Also there is two black lines coming from the lower back of the receptacle and I'm not sure what they are for. Thankyou for your assistance
Sharkbait0615 is offline   Reply With Quote
Old 06-28-2012, 11:55 AM   #2
Rewards Points: 6,652
Yes, if that is the only way. Otherwise, if you can pull a dedicated circuit for the outlet, then try. A lot of older homes that have not had wiring updated, you will find that the baths and kitchens do not have gfci outlets, along with the garages, outside outlets and basements.
Old 06-28-2012, 12:03 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Is this what you bought?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-28-2012, 03:09 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Are you installing this combo device so you have a receptacle? If so, that wouldn't pass code. If you are installing a receptacle in the bathroom, it would need to be on a dedicated 20A circuit.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (06-28-2012)
Wiring an outlet to a switch, to a light Athens Electrical 5 01-04-2012 07:03 PM
Combo light switch outlet re-wire question seasidediy Electrical 3 07-21-2011 05:02 AM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 12:31 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
GFCI light switch trips once per night ???? mw6263 Electrical 11 07-25-2008 11:05 AM
