GFCI Switch To Control Outside Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 09-07-2008, 09:36 PM   #1
GFCI switch to control outside outlets
What I'm attempting to do does not seem to be working so it may not be possible or I'm not setting it up correctly. FYI: I'm a very ignorant of things electrical.
What I HOPE to do:
Bottom line is I would like to have two sets of outlets outside. One set is "always hot" and the other set's power controlled by a switch indoors. This switch controlled set of outlets will be for a small outdoor fountain so we can control the on/off indoors.
What is happening:
I've got a leviton GFCI switch which has a set of terminals to send 'always on' power to an outlet.
The "always hot" outlets work fine.
The outlets attached to the switch leads get no power.
I FEEL I have wired things according to the diagram in the switch's instructions but being electrician illiterate, I don't understand allot of the verbage.
The "always hot" outlets are wired from terminals on the switch that are designed to go out to another outlet in "always hot" mode. WORKS FINE.
The switch controlled outlets are wired to the two black "switch leads" coming out of the switch unit. These leads are both black wires and the diagram shows one going to the black of the wire going to what they call the "Switched LOAD" and the other black wire going to the white of this same "Switched LOAD" wire. This "Switched LOAD" is what I have going to the outside outlet I want controlled by the switch. NOT WORKING.
Is it even possible to run the switch lead wires to power an outlet?
If so, any insights in where I may have wired incorrectly?
Thanks for ANY insights!
Bill in Sacramento
billgeo is offline   Reply With Quote
Old 09-07-2008, 09:50 PM   #2
is this what you have? what is the model number?
Willis
williswires is offline   Reply With Quote
Old 09-07-2008, 10:05 PM   #3
sure looks like it. Lemme see if I can find the number on this instruction sheet. (looking... looking... )
Hmmm. maybe this; di-000-07299-02a-x4
Old 09-07-2008, 10:21 PM   #4
yep, that's it.
I don't have the instructions that came with the device (can't find it on Leviton's site either).
Based on their spec drawing, this should work. Does this resemble anything on the device instructions??
The spec drawing does not identify the two wire leads as either "hot" or "neutral", which would be required if they were indeed hooked up to the hot and neutral of an outlet. They appear to be generic switch leads - hot in one lead, hot out the other when the switch is "on", and having the added benefit of being disconnected in the GFCI should a ground fault occer because the power would come from the LOAD terminals.
Willis
Old 09-07-2008, 10:47 PM   #5
Very good. LOL. Thanks
It is slightly different that what the instructions show. Lemme try to explain the difference. The difference is only on the "switch leads"
It shows both switch leads going to the "Switched LOAD" (which is my outlet). One via the black and the other via the white.
You show the switch lead on the HOT side going back into the switch's HOT LOAD and the other going to the outlet via the black (HOT) wire and the outlet's white (neutral) wire going back into the switch's neutral LOAD.
I scanned the instruction's diagram but I guess it was too large to upload. Sorry.
Bill
Old 09-07-2008, 11:19 PM   #6
go to photobucket.com
upload your photo to their site.
under the photo at photobucket, copy the address that appears in the "direct link" line under your picture
In this forum, click the mountain picture "insert image". paste the direct link in the pop-up box and submit your post
Willis
Old 09-07-2008, 11:20 PM   #7
Is one switch lead black and one white - or are they both black?
waiting to see their instructions...
Willis
Old 09-07-2008, 11:34 PM   #8
Both switch leads are black.
Working on the instructions
Old 09-08-2008, 09:19 AM   #9
It appears as though the switch leads are isolated from the gfci circuitry, just as if it were a separate device. The drawing as shown has the switch leads wired as part of a "switch loop".
Since you are wanting to use the switch to control the second outlet, using my prior diagram will accomplish what you wanted. All 3 outlets will be gfci protected, the main one on your device and the 2nd one will always be hot, and the 3rd will be controlled by the switch.
I recommend using the back-wire holes. To use the back wire holes, power off, make sure the screw is loosened, strip your wires, place them through the hole in the back and tighten the side screw to tighten the clamp which secures the wires for that particular terminal.
Test your gfci at each location.
Let us know how you made out.
Willis
Old 09-08-2008, 09:43 AM   #10
Rewards Points: 81
Here is the diagram redrawn. It is the same as what williswires drew previously.
daxinarian is offline   Reply With Quote
Old 09-08-2008, 09:45 AM   #11
Thanks Willis
I'm at work now so I'll try your setup this evening and let you know.
Either way, that's for all your effort on this.
Bill
Old 09-08-2008, 09:47 AM   #12
Thanks daxinarian!
Old 09-08-2008, 10:15 AM   #13
Now that drawing was just sah-weet! Nice coloring.
Willis
Old 09-08-2008, 10:26 AM   #14
Rewards Points: 81
Thanks, I get lots of practice coloring with my 3 yr old daughter
and your welcome Bill
Old 09-08-2008, 11:09 PM   #15
woooooHOOOOO it WORKS!
Thanks Willis for your insight!
and thanks daxinarian for the saaaaaaaaah-weet
GFCI light switch trips once per night ???? mw6263 Electrical 11 07-25-2008 11:05 AM
Adding hot outlets to 3-way switch KJG67 Electrical 8 04-22-2008 11:53 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 09:31 AM
