GFCI And Single Pole Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2011, 06:05 AM   #1
GFCI and Single Pole Switch
I have an outlet that I'm replacing with a GFCI (its an old house with no ground wires). This outlet is connected to a single pole switch. The power (2 wires, black and white) goes to the outlet and then there are another 2 wires (black and white) going from the outlet to the switch. Is it possible to wire this? What would I need to do to get this working?
Everything I tried either trips the GFCI when I turn off the outlet or just trips the whole breaker when I reset the GFCI.
bob9785 is offline   Reply With Quote
Old 07-08-2011, 06:21 AM   #2
Rewards Points: 1,448
Does it trip even if nothing is plugged into the outlet and any light also connect to the switch has its lamp unscrewed?
Double check your wiring in the outlet box to have: White from power cable to line side silver or white (or receptacle body side with larger prong slots) of receptacle unit. Black from switch cable to line side gold or black (side with smaller prong slots) of receptacle. Other two wires connected to each other. Nothing connected to load side terminals of receptacle unit. All ground wires (green and/or bare) to each other with an extra length of bare wire connected to receptacle green screw if no green wire already provided.
Old 07-08-2011, 07:31 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
You can not wire this gfci up.
Modern GFCI receptacles require power to be able to reset.
When you turn the switch off, kill power to the gfci, then you have to reset it everytime you need it.
You can lose the switch if you need gfci protection.
I was incorrect about this info, so please disregard.
jbfan is online now   Reply With Quote
Old 07-08-2011, 10:43 AM   #4
Licensed Pro
Not sure that's correct... yes, you need power to initially reset the GFCI, but unless it trips, it should power up each time the switch is turned on without having to be reset.
Old 07-08-2011, 10:56 AM   #5
Master Electrician
Rewards Points: 3,768
Agreed. That has been my experience.
brric is offline   Reply With Quote
Old 07-08-2011, 08:33 PM   #6
When you turn the switch off, kill power to the gfci, then you have to reset it everytime you need it..
Are you sure?
That would mean that in case of power failure, all the GFCI units in the house would trip and need to be reset when power is restored. Increase the chance of food spoilage if a refrigerator had to be plugged into a protected receptacle and then did not get its power back automatically when power was restored.
I don't recall this happening in my house, however all the GFCI's are more than 4 years old.
Old 07-08-2011, 11:03 PM   #7
Originally Posted by AllanJ View Post
Double check your wiring in the outlet box to have: White from power cable to line side silver or white (or side with larger prong slots) of receptacle unit. Black from switch cable to line side gold or black (side with smaller prong slots) of receptacle. Other two wires connected to each other. Nothing connected to load side terminals of receptacle unit. All ground wires (green and/or bare) to each other with an extra length of bare wire connected to receptacle green screw if no green wire already provided.
Thanks! That was the issue, the wires were not setup correctly. They originally (just purchased the house), had pig tails for the black wire from the outlet and black wire from the switch, and that would be reversed anyway for a normal outlet, I think.
But this setup works with the GFCI, and the GFCI does not trip when the switch is turned off.
(I'll also mention that these were all brand new Leviton SmartLock GFCI's purchased at home depot a couple days ago.)
Old 07-09-2011, 11:40 AM   #8
jbfan's Avatar
Rewards Points: 254
See my edit in post #3!
Old 07-16-2011, 12:05 PM   #9
Here is a diagram for a switched receptacle. It is not GFCI but the wiring principals are the same http://www.howtoelectric.com/diagram...wiring-diagram
tdfulk is offline   Reply With Quote
2 Single Poles to 1 Double GFCI Breaker nuckphoto Electrical 24 11-11-2010 12:40 AM
how do I hook this up? gfci to switch Limit54 Electrical 3 06-14-2010 12:22 PM
3 wire romex for single switch jraf Electrical 4 04-06-2010 09:46 PM
single pole switch for jacuzzi tub kodeblue Electrical 6 09-19-2009 12:48 PM
GFCI & Single Pole Switch combo II Weeks Electrical 12 04-10-2009 06:57 PM
